2018+ Softail Models Breakout
Plastic Frame Plugs
Old Sep 16, 2020 | 06:52 PM
P51Driver's Avatar
P51Driver
Default Plastic Frame Plugs
Well I sit here with my new 2020 Heritage Classic and I am getting ready to install the engine guard I just picked up. But for the life of me I can't figure out how to get the little plastic frame hole plugs from the lower front frame holes without scratching the frame with a screw driver or something trying to pry the head of the plugs. What did you guys use or how did you remove these plugs without scratching the frame all to $hit?
Old Sep 16, 2020 | 07:00 PM
joey3257's Avatar
joey3257
Drill a small hole. Run a sheet metal or drywall screw into the hole, then yank the plug out with a pair of pliers.
Old Sep 16, 2020 | 07:01 PM
luckiestiff's Avatar
luckiestiff
use the point of a knife, lift up one side carefully then snag it with needle nose pliers
Old Sep 16, 2020 | 07:22 PM
470004's Avatar
470004
That the method I also use.
Old Sep 16, 2020 | 07:53 PM
iHodor's Avatar
iHodor
Poke it out from the other side if you can get something in there.
Old Sep 16, 2020 | 07:58 PM
DonN's Avatar
DonN
I pulled one side out with vicegrips. Then realized they unscrewed. So but a short flathead on other side, tapped in to secure then unscrewed it.
Old Sep 16, 2020 | 08:43 PM
P51Driver's Avatar
P51Driver
All good ideas. Now I am thinking a easy out would work as the plastic plug is in a threaded hole.
Old Sep 16, 2020 | 09:49 PM
OldMike's Avatar
OldMike
Heat the tip of a screwdriver, insert into the plug and turn it out.
DO NOT PRY IT OUT AND SCRATCH YOUR NEW FRAME!
Old Sep 16, 2020 | 10:49 PM
P51Driver's Avatar
P51Driver
Wow you come up with some good ideas even in your old age.
Old Sep 17, 2020 | 12:57 AM
FXLRyan's Avatar
FXLRyan
key word is careful. Did this for all of mine
