2018+ Softail Models Breakout
Stage 2 question
Old Oct 2, 2020 | 09:09 AM
ss3964spd's Avatar
ss3964spd
Originally Posted by Tampa Fatboy
If done correctly, they do the job. Now if you wish to pull the top end for perfection then you should do the jug upgrade.
The "job" they are designed to do is to make cam swaps easier which, coincidently, helps drive product sales. Marketing, being what it is, touts the benefits of the product, but almost never does it point out the potential risks. Everyone makes their own cost/benefit analysis based on the information they have, or may not have. For me, I'd really rather not risk floating the valves or having an adjustable push rod come loose.
Removing the rocker covers and rocker shafts isn't even remotely similar in time, complexity, or expense to pulling the top end (heads).
Old Oct 2, 2020 | 09:15 AM
Hdbkstl's Avatar
Hdbkstl
I have read about the weight difference in adj. pushrods vs non. Some say it doesn't matter in modern engines some say it does. Potato pahtato. The biggest disadvantage with the adj pushrods comes from the potential of flex. Even that is mitigated by going with a reputable company, and unless you are doing crazy hp/tq numbers, which you are not, you will be just fine.
Old Oct 2, 2020 | 09:48 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
It is to my impression that if FuelMoto and others are confident about using them in stage2 and big inch builds, they cant be that much of a risk.
I got the Wood 22X cam kit from fuelmoto in my wishlist, and it comes with the fuelmoto adjustable push rods. Combined with Feuling's lifters, I really don't think I have any reason to worry about em on a stage 2 build.
I'm far more concerned about blowing apart the compensator than a pushrod.
Old Oct 2, 2020 | 09:58 AM
Hulkss's Avatar
Hulkss
Adjustable pushrods exist for only one reason - for mechanics who are in too much of a hurry to do a proper job by removing the fuel tank and rocker covers. Some cams do require shorter push rods which are available in a one piece design as well.
Old Oct 2, 2020 | 10:16 AM
ss3964spd's Avatar
ss3964spd
The laws of physics doesn't care if the engine architecture is modern or not. In regards to this application it could well be that the valve springs are stiff enough to control the extra mass of the heavier push rods at higher RPM's but I've not seen anyone confirm, in writing, that that is the case.
Flex is definitely a potential issue. Reputable company or not, there is only so much they can do within the tight confines of the push rod tubes. They can't makes the PR's much fatter because the adjusting nut would then have to be larger and then wouldn't fit in the tube. They can heat treat them, and they do, but that makes the PR's more brittle. They have to make them smaller diameter, but with much thicker walls to accommodate the threads, which makes them heavier. Trade off's.
The valve train doesn't care about Hp/Tq numbers, it isn't under any additional stress as power levels rise. The only thing the VT has to manage is the mass of the components that comprise it, at the reciprocating speeds it must run.
Old Oct 2, 2020 | 10:24 AM
Hulkss's Avatar
Hulkss
An issue with adjustable push rods is improper adjustment. Many reports of people adjusting and re-adjusting. Another problem is the lock nut coming loose while riding. In an effort to prevent loosening, the lock nuts get over torqued (few people have a torque wrench that can get onto a pushrod). This can crack the nut or pushrod leading to a major failure.
Old Oct 2, 2020 | 12:18 PM
Norcalslinger's Avatar
Norcalslinger
Thanks for all the info and varying options. I talked to FM and they did say they use a ton of adjustable pushrods even in big bore builds. I will be using the S&S ones. Looks like I will be purchasing fueling lifters as well. Seems the consensus is to change them.
Old Oct 2, 2020 | 12:25 PM
SoCaRider's Avatar
SoCaRider
Good call 👍
Old Oct 20, 2020 | 11:51 AM
FranBunnyFFXII
For anyone still curious about Adjustable Pushrods, Skunkworks uses them in their high end builds.
Old Oct 20, 2020 | 03:36 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I've put a lot of miles on various scoots with cam upgrades and adjustable push rods and never a problem.
Like I suggested earlier, if you wish prefection, go the extra mile and do the friggin jug upgrade while youre there, Mr join date June 2020.
My previous comment was a little positive input. There is a 11:1 piston kit fit those jugs and give it more performance if you have the time and money. Have to choose a different cam tho, the torque cam only allows 10:1 pistons.
