2018+ Softail Models Breakout
Need electrical help
Old Oct 18, 2020 | 12:44 PM
Jeremy.briscoe1984's Avatar
Jeremy.briscoe1984
Default Need electrical help
I am a novice electrician at best. I have some LED strips and a set of fog lights that I want to be able to turn on when the bike isn't running. I did some research and set up the whole circuit on my work table with a 12v power supply and everything works great. I hooked it up on the bike and nothing. Can these lights not be hooked straight up to the battery? I know I haven't provided much detail. I'm hoping that those of you who are not novices will know what questions to ask and I'll do my best to answer. Thanks all
Old Oct 18, 2020 | 12:55 PM
GalvTexGuy's Avatar
GalvTexGuy
+ to + and - to -?
Old Oct 18, 2020 | 01:07 PM
Jeremy.briscoe1984
Originally Posted by GalvTexGuy
+ to + and - to -?
+ to +, but i tried - to ground because of how difficult it is to get to the negative terminal. Is this an obvious problem?
Old Oct 18, 2020 | 02:19 PM
Tampa Fatboy's Avatar
Tampa Fatboy
DC voltage, black is negative. Fuse it, and throw a switch in there.
Not comfortable with it? LED guys are not that pricey. Most swap meets find them.
Old Oct 18, 2020 | 04:13 PM
Jeremy.briscoe1984
Switched the ground to negative. All's well. Thanks guys.
ABQ-Jammer
Electrical/Lighting/Alarm
Oct 2, 2019 10:59 AM
HOG_0308
Nov 26, 2011 04:00 PM
pault105
Jan 20, 2010 09:59 AM
Motorboatn SOB
Nov 24, 2008 12:42 PM
gto frank
May 23, 2006 06:07 AM
