2018+ Softail Models Breakout
Another Exhaust Question.
Old Jan 5, 2021 | 10:28 AM
Calton1's Avatar
Calton1
Default Another Exhaust Question.
I went to dealer yesterday and asked about slipon exhaust. I have a 19 Heritage Classic 114. I was told that after purchasing slipons, I would need a tuner, and then “4” hours on the Dyno. Told cost would be around 1200$. Is this right?
Old Jan 5, 2021 | 11:45 AM
slw210's Avatar
slw210
That would be incorrect AFAIK, mine runs just fine after installing Cobra NHs. That said, any bike could most likely benefit from a good tune and a run on a dyno, even stock.
Where in Florida?
Old Jan 5, 2021 | 12:08 PM
Calton1's Avatar
Calton1
Charlotte County. Thanks. I thought the 4 hours was a bit much.
Old Jan 5, 2021 | 12:57 PM
FatBob2018's Avatar
FatBob2018
The standard line from Harley is that slip-ons require ECM recalibration using the Screamin' Eagle Pro Street Tuner. That doesn't require ANY dyno time, but it does require buying a $300 tuner and then downloading the appropriate tune.
Old Jan 5, 2021 | 02:27 PM
Calton1's Avatar
Calton1
Thank You. I can do slipons myself. Is the tune something I can do?
Old Jan 5, 2021 | 02:32 PM
Steve Sportster's Avatar
Steve Sportster
I put Vance & Hines Eliminator 300s on my 2018 FLHCS (Heritage) without the quiet baffles. Too much decel "popping" so I added V&H quiet baffles. Bike ran okay, but it sure runs a lot better with a V&H FP3 tuner programmed for the new exhaust. My opinion: custom tuning is over rated. V&H does a great job with their programmed tunes. Could I get more out of the bike with a custom dyno tune? Possibly, but why would I bother if I'm very satisfied with the tune that's in it. If I want, I can run auto tune or even get with V&H to customize the tune further for free. By the way, their tech service folks are great. Well worth the $400 IMHO.
Old Jan 5, 2021 | 03:09 PM
470004's Avatar
470004
You may want to look into the Dynojet Power Vision Tuner.
Old Jan 5, 2021 | 03:54 PM
GalvTexGuy's Avatar
GalvTexGuy
If your bike is still under warranty, you will void the powertrain warranty if you install any tuner other than the H-D Screamin' Eagle Pro Street Tuner. If it's not under warranty, never mind.
Old Jan 5, 2021 | 04:30 PM
Calton1's Avatar
Calton1
Still under warranty until Sept.
Old Jan 5, 2021 | 05:15 PM
FatBob2018's Avatar
FatBob2018
Definitely. Buy the tuner, and the cables (sold separately); download the SEPST software, and you can download the tune, and you can also run autotune sessions to dial it in better to your specific bike.
