2018+ Softail Models Breakout
Handle bar problems
Old Jan 29, 2021 | 10:03 PM
AKG's Avatar
AKG
Stage III
Default Handle bar problems
Hey everybody! Hope you’re all doing well, here’s the deal, I switched the handle bars on my 2020 FXBB, everything works great, I pulled the fuse before I started , but still the check engine light came on, I ran diagnostics and everything was cool except for ABS said N and I got a PN 40800074C code , anyone got any ideas what’s up with that? Thanks in advance
Old Jan 30, 2021 | 02:14 AM
Mart's Avatar
Mart
Sorry, no direct experience, but every couple of months there are similar posts about electrical problems post handlebar swap. The fix has usually been tracing the wiring and finding a connection that's dislodged, unexpectedly loose, or not been reconnected. Hope that helps.
Old Jan 30, 2021 | 04:59 AM
jtodd's Avatar
jtodd
Did you have to change the upper brake cable for these bars? If so, how did you bleed or flush the brake line?
Old Jan 30, 2021 | 06:49 AM
Grundee's Avatar
Grundee
Ive had this happen too.
After a few hours of riding it went out.
Make sure everything works before you ride... then go ride.
Old Jan 30, 2021 | 09:32 AM
AKG's Avatar
AKG
Stage III
Default Thanks
Thanks everyone, I rechecked and did a more thorough zip tie job to super clean everything up and then cleared the codes and that seems to have done the trick, I think one of the connectors got loose when I put stuff back together the first time
brawner11
Mar 27, 2020 09:29 AM
dave the welder
Milwaukee Eight (M8)
Mar 23, 2019 12:06 AM
Air_Lars757
Apr 27, 2016 01:57 PM
johngbrown66
Jul 3, 2012 03:07 PM
Talldog
Jul 27, 2011 11:37 AM
