2018+ Softail Models Breakout
Looking for a easier clutch pull
Old Mar 31, 2021 | 07:30 PM
Herbkell's Avatar
Herbkell
Default Looking for a easier clutch pull
I have a 2019 FLHCS. I AM 72 and am experiencing the rapid onset of arthritis in my hands. I haven’t ridden since last fall and as it was a nice spring day I was excited to get out for a ride. Unfortunately it was a real struggle and my left hand really hurt with each clutch pull. I had to stop a couple of times to give it a rest.
I would hate to give up riding and hope to find a solution. My quick research has discovered products by Müller and AIM that apparently reduce the pressure required by up to 40%. Unfortunately they only seem to fit M8 touring models and not the Softails.
Does anyone know of another solution
Thanks in advance
Old Mar 31, 2021 | 08:00 PM
Steve Sportster's Avatar
Steve Sportster
I also have arthritis problems with my right hand. Anti-inflamatory OTC medications help. Prednisone helps a lot. I find it is worse at the beginning of the riding season and gets better through the summer. I know this is not a mechanical fix to the bike, but it's what helps me.
Old Mar 31, 2021 | 09:37 PM
Burbur2's Avatar
Burbur2
I installed easy pull clutch lever from JP cycle 26$ !!!!
Old Mar 31, 2021 | 11:56 PM
OldMike's Avatar
OldMike
Check out the Hulkss tips about easy pull clutch here:
https://www.hdforums.com/forum/2018-...l#post19085949
Old Apr 1, 2021 | 12:23 AM
Hulkss's Avatar
Hulkss
Yup. The Rekluse clutch pack works great. I would stay with the stock 19 degree ball ramps (2018-2019 models) if I was doing it again. HD has changed the clutch ramps to 21 degrees now. That increases the clutch release travel and makes the clutch pull harder. See attachment.
H-D did this because some people don't adjust the clutch properly and then can't find neutral easily because the clutch is dragging.
File Type: pdf
Old Apr 1, 2021 | 09:33 AM
Herbkell's Avatar
Herbkell
Thanks for the information.gentlemen
I will look into your recommendations
Old Apr 1, 2021 | 10:16 AM
Burbur2's Avatar
Burbur2
ha! I might do video on my YouTube on this. Thanks for sharing this bulletin
Old Apr 1, 2021 | 02:17 PM
Riotfunk's Avatar
Riotfunk
Change the levers. Easy fix and makes it easier. The factory ones are really stretched out to grab. I went to some trigger shortys and can pull easily with one finger to clutch now instead of having to mitt the whole clutch lever
Old Apr 1, 2021 | 03:09 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Lube the ccable, one of the most neglected thing an owner is guilty of. Do not use WD40, grab the the lil syringe lube from HD
NiteOwlNY
2014-2024 Touring Models
35
Oct 26, 2018 03:15 PM
John Newsom
Oct 3, 2016 10:39 AM
flagirl
28
May 31, 2013 01:24 PM
Lady Deluxe
Jul 1, 2007 07:39 PM
