2018+ Softail Models Breakout
Custom dynamics triple play
Old Apr 30, 2021 | 09:40 PM
Timberjkd's Avatar
Timberjkd
Default Custom dynamics triple play
Hey guys I had my 19 heritage flashed so the signals would double as brake lights. I really wanted run lights too but dealer said it wasn't an option. I bought the custom dynamics triple play module and everything works well except when I release the brake the signals go out for a second and then come back on as running lights. Is this normal? I looked all over YouTube and found a bunch of videos with the leds but not the stock bulbs. Any advice or is this a programming issue?
Old May 1, 2021 | 01:51 AM
OldMike's Avatar
OldMike
On mine with Triple Play:
Brake on, brake off and turn signal on is instantaneous.
Just turn signal off, whether using brake or not, does a slight time out.
I did not have anything enabled by dealer before the install.
Old May 1, 2021 | 07:56 AM
Timberjkd's Avatar
Timberjkd
I wonder if the dealer flash is the problem. That sucks if I have to go back to have them disable it.
Old May 1, 2021 | 08:53 AM
ss3964spd's Avatar
ss3964spd
The dealer flash is the problem, Timber, I did the exact same thing. Had it flashed, then I installed the TP. Wasn't working right so called CD, they confirmed it was the flash.
Old May 1, 2021 | 10:31 AM
Timberjkd's Avatar
Timberjkd
ugh....ok. well...off to the dealer i go. Damn it! Lol. Thanks for the info guys. It seems a little silly that the HD flash doesn't allow the signals to perform that function. Thanks again.
Old May 1, 2021 | 10:33 AM
Timberjkd's Avatar
Timberjkd
quick question...did you have to remove the CD module b4 you took it back to the dealer or just leave it on.
Old May 3, 2021 | 07:48 AM
ss3964spd's Avatar
ss3964spd
Just leave it in place, Timber, won't hurt a thing.
fhartell14
Jul 8, 2017 11:48 AM
14StreetG_cruiser
Electrical/Lighting/Alarm
Mar 27, 2017 11:06 AM
cathead
Jun 7, 2015 10:20 AM
lowridermike
Dec 16, 2009 11:47 AM
blz2503
May 21, 2009 12:09 PM
