2018+ Softail Models Breakout
2021 Softtail Slim query
Old May 2, 2021 | 07:14 PM
Rustyg500's Avatar
Rustyg500
Default 2021 Softtail Slim query
1). Looking at the Softtail slim and noticed two spark plugs per cylinder. Also noticed there is not much room to get a wrench in there to remove old ones and install new ones. Does one have to remove or displace the gas tank in order to replace the plugs?
2). I also noticed when starting the bike up and revving the engine that the engine does not seem to follow the throttle when releasing the grip but rather slowly (1 to 2 seconds) returns to idle. Is this normal or should the engine follow the throttle grip like my 2002 Road King does? The salesman said this is normal until the bike warms up.
Old May 2, 2021 | 07:59 PM
Uncle G.'s Avatar
Uncle G.
According to the owner’s manual you have to remove the tank to change the plugs. Some here say you can do it by raising the rear of the tank only. At best there’s still damn little clearance to access the right rear plug due to the proximity of the oil lines.
Just one more annoyance of modern life.
The cold throttle response sounds about like my Heritage. That’s the “throttle by wire”.
Old May 3, 2021 | 06:33 PM
Rustyg500's Avatar
Rustyg500
Thanks Uncle G.
turckster
Feb 27, 2017 10:59 PM
ScreaminEagle2007
Mar 15, 2012 08:35 PM
Reblyel
Dec 22, 2011 09:34 PM
wildroot
Aug 21, 2010 08:06 PM
seven7
Apr 20, 2008 07:57 PM
