2018+ Softail Models Breakout
Need some advice on bar wiring.
Old May 5, 2021 | 07:05 AM
MCSarge's Avatar
MCSarge
Originally Posted by SofaKingTired
You bet - If you get to using those clamps from Amazon - I found a few tricks to make them fit up and lock in pretty well - feel free to reach out!
Post them up please to help us and others if they do a search......
Old May 5, 2021 | 10:09 AM
SofaKingTired's Avatar
SofaKingTired
Nothing crazy:
-I used all stock hardware accept for the clamp its self - using the swivel post through the clamp as the connection point (it clears the fork tube, and is short enough to pull the signal in tight to the clamp)
-Throw a washer between the signal and the clamp - this will allow you to lock them down, yet prevents the clamp from forcing the lens angle.
-lock in the the forward hardware on the clamp first. there will be a small gap - might as well hide it behind the tubes.
-Use thread locker...
Pretty basic - but may save you some time on your install, and from finding your signals dangling by their wiring, or just pointed at the ground...
Old May 6, 2021 | 02:05 AM
dd666's Avatar
dd666
Thanks. Some good info. Will post pics when I get done.
Old May 6, 2021 | 11:11 AM
SofaKingTired
Awesome! looking forward to them!
Old Jul 15, 2021 | 11:19 AM
SofaKingTired
Nothing crazy:
@Wheazy Here you go!
JSager89
General Topics/Tech Tips
Nov 30, 2017 01:23 PM
USAproud
Sep 27, 2017 04:08 PM
Ashnic
Feb 24, 2017 09:37 AM
dslkraz
Mar 27, 2011 01:20 AM
Biffmaster2000
Nov 22, 2009 08:05 PM
