2018+ Softail Models Breakout
M8 , idle speed
Old Oct 13, 2022 | 09:39 PM
Rabianegra's Avatar
Rabianegra
Originally Posted by tngarren
You must be an H-D service tech. No, they all don't do it. Fortunately, found another post with identical problem. Found a hairline crack in the cheap plastic intake manifold. Shame on you H-D. $20K bike and plastic manifold. Replaced it with an S&S aluminum one. Good coasting idle, just like my 2 previous M8s.
Well, mine certainly does it and I honestly thought that all of them did it because the MoCo wanted them to do it. I don't pay much attention to it, anyway...
I'm taking it to the dealer today for the 10k miles inspection and will certainly ask them about this.
Thanks for the heads up!
Old Oct 14, 2022 | 05:23 AM
tngarren's Avatar
tngarren
You may find this link helpful. Best to you.
M8 Idle Issue Solved - Harley Davidson Forums (hdforums.com)
Old Oct 14, 2022 | 07:00 AM
hellonewman's Avatar
hellonewman
My 3 twinkies did the same thing, turned out its a strategy in the ecm but I forget where I found that out.
Old Oct 14, 2022 | 05:51 PM
felix27's Avatar
felix27
How difficult is it to check the intake manifold, I think I have this crack problem?
Thanks
Old Oct 14, 2022 | 07:14 PM
tngarren's Avatar
tngarren
Thanks
I tried the easy propane trick and found nothing. I had to remove the manifold to fully check it. Yours could be slight warped instead of cracked and not making a good seal on the intake ports. The stock one is so cheaply made, once you have it off, you might as well put on a good one for around $200.
The job is not technically difficult, but it is annoying getting to the hex bolts on the two intake ports. I had to remove the coil to access the lower bolts. Good video below. The shop manual is also your friend.
Old Oct 14, 2022 | 07:15 PM
tngarren's Avatar
tngarren
What is a twinkie?
Old Oct 14, 2022 | 07:17 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
What is a twinkie?
Twin Cam.
Old Oct 14, 2022 | 07:28 PM
tngarren's Avatar
tngarren
Interesting. I had to call Fuel Moto because a tune wiped out my cruise control, so I asked about the coasting high idle. Lucas said some bikes do it by ECM design. I'm glad mine was a cracked intake manifold that was fixable. I hated coasting to a stop with an idle at 1.5 - 2K. Sounded downright silly.
Old Oct 28, 2022 | 11:28 AM
felix27's Avatar
felix27
I think this should have been: " some do it by Defect".
Old Oct 29, 2022 | 03:45 AM
Phil13's Avatar
Phil13
This was a subject bought up by more than a few new car owners in the UK, why the revs seem to "hang" when you're slowing down by changing to a lower gear or coming to a halt. The explanation given was this is to enable the motor to burn any excess fuel in the inlet manifold as the car slows so as to keep the emissions lower than they would otherwise be.
