2018+ Softail Models Breakout
Swing arm bolt issues
Old Feb 8, 2022 | 01:46 PM
Rick801's Avatar
Rick801
Stage III
Default Swing arm bolt issues
Swing arm issue I am building a 2001 Harley Davidson heritage classic and am having issues with getting swing arm as well as rear axle bolts that fit I've bought 3 different bolts and none have been long enough to use they have been 13 and 13 1/4 inch the issue I'm having with the swing arm bolt is I have inserts that stick out on the outside of my swing arm about a half inch each making the bolt to short does anyone know what bolt I need to get to fix this issue my rear axle bolt has the same issue of not being long enough please help
Old Feb 8, 2022 | 02:12 PM
HuntWhenever's Avatar
HuntWhenever
There is a separate forum section for the pre-2018 Softails. You may have better luck getting some expert advice over there.
Old Feb 8, 2022 | 02:27 PM
Rick801's Avatar
Rick801
Stage III
Sorry thank you
Old Feb 8, 2022 | 05:20 PM
HuntWhenever
Originally Posted by Rick801
Sorry thank you
No problem. Good luck with the swingarm!
Old Feb 8, 2022 | 06:01 PM
chopper_man's Avatar
chopper_man
You sure the new bushings are not in backwards? I can see those spacers needing to point towards the swingarm. Just guessing, doesn't look right to me.
Old Feb 10, 2022 | 07:23 AM
uncle kebo's Avatar
uncle kebo
I was JUST gonna say that - IMO, its not the bolts..
Old Feb 15, 2022 | 04:40 PM
IBE's Avatar
IBE
what happened to the ones that were in it??
VazquezFXDP
Oct 28, 2018 09:05 AM
rggranlund
May 25, 2015 05:32 PM
rggranlund
May 25, 2015 02:11 PM
PhantomMaxx
May 19, 2015 12:38 PM
ramu3527
Mar 19, 2014 04:09 PM
