2018+ Softail Models Breakout
2020 FLHCS exhaust removal problem
Old Mar 6, 2022 | 03:56 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by Rampant Piper
It is mounted to the bracket-attached to two bolts that go to the transmission case
I understand what the bracket is and where it’s mounted. Did you read the instructions? The instructions tell you to secure the bracket to the transmission case first so the pipes can be properly aligned in the exhaust ports to prevent exhaust leaks.
From the instructions:
7. Using stock flange nuts, carefully install the header assemblies onto the motorcycle.
Finger tighten only at this time.
8. Use the nut plates and 5/16” x 5/8” flange bolts (supplied) to attach the pipes to the bracket. Do not tighten at this time.
9. Align pipes on motorcycle so the gap between the two muffler bodies is consistent from front to rear. Tighten the exhaust port flange nuts and the 5/16” x 5/8” flange bolts.
mrbeads
Aug 14, 2018 08:05 AM
PartyInValhalla
Softail Pictures
May 14, 2017 02:20 PM
thebizz42
Mar 22, 2017 05:24 AM
OldTyme
Sep 28, 2012 05:33 PM
bbqbrisket
Engine Mechanical Topics
Jan 22, 2010 04:01 PM
