2018+ Softail Models Breakout
Harley M8 Spark Plug Schedule
Old Apr 21, 2022 | 04:38 PM
Las Vegas Jim's Avatar
Las Vegas Jim
Thumbs up Harley M8 Spark Plug Schedule
HD recommends changing spark plugs every two-years or 8k to 10k miles on an M8. I had a little over 10k miles on my SE spark plugs; so, I changed the plugs yesterday. (I like to do my own maintenance within the limits of my skills and tools.) Changing the plugs on an M8 engine isn't a difficult task, if you have a little patience; it took me about 30 minutes.
The spark plugs had the correct color for plugs in a properly tuned engine and looked in good shape. But, I had bought a set of NKG Iridiumix spark plugs; so, I went ahead and changed the plugs since I had the time. I then took my bike on a 25+ mile test run. I was surprised at the improvement in performance, particularly accelerating from a full stop and on low speed maneuvers. Overall the throttle response was more precise, smoother and quicker.
Moral of story. HD's recommendation is spot on. Spark plugs are another maintenance item, like fluid changes, for which owners should follow HD's service interval recommendation even if you feel the bike is running well.
Old Apr 21, 2022 | 04:50 PM
Uncle G.'s Avatar
Uncle G.
My book says, "every two years or 30,000 miles" (2019 Softail owner's manual).
Old Apr 21, 2022 | 04:53 PM
702's Avatar
702
Where did you find the 8-10 thousand mile recommendation? Every M8 chart I've seen is the same - 2 years or 30k miles.
Old Apr 21, 2022 | 04:57 PM
strych9's Avatar
strych9
8-10K? That's incorrect.
As for time...I ignore that when it comes to spark plugs. Mileage only.
Old Apr 21, 2022 | 05:02 PM
702's Avatar
702
Why the switch to iridium?
Old Apr 22, 2022 | 07:52 AM
MoneyFor's Avatar
MoneyFor
As said here before, mileage only.
Old Apr 22, 2022 | 08:51 AM
smitty901's Avatar
smitty901
M8 is 30,000 . My 2017 had first change at 29,500 plugs still fine . but once out new goes in.
Old Apr 23, 2022 | 01:03 PM
Las Vegas Jim
You are correct; my book says the same. But, several third-party reviews and local HD mechanics are experiencing that spark plug wear on the M8 engines is occurring faster than HD originally projected.
Old Apr 23, 2022 | 01:06 PM
Las Vegas Jim
I switched to the iridium plugs to see if the projected improvement in initial acceleration was real. So far for me, the improvement has met the hype.
Old Apr 23, 2022 | 06:40 PM
702's Avatar
702
Interesting, I hadn't heard that. I change them every spring regardless of miles. Changed them yesterday in fact. They showed no signs of wear, and were still gapped within spec after 17k miles and one year.
I hope you find the time to come back here and share your thoughts as time and miles rack up.
