Changing Brake Fluid???
To answer OP question if you have ABS 2 years. If not test and replace as needed.
Yes you can do it your self many products on the market to cycle ABS.
When the NHTSA Office of Defects Investigation (ODI) sent inquiry letters to H-D and Dow regarding the brake fluid stability issues, Dow responded with a confidential submission, which has me wondering what was Dow hiding? Though H-D placed blame for the HCU failures squarely on the shoulders of owners for failing to change the fluid at the recommended two-year interval and/or when moisture content was more than 3%, I cant help but think that Dows stability issues brake fluid was more responsible for HCU failures than we know.
It is also worth noting that there was at least one other commercially available brake fluid, if not more, during the time these bikes were manufactured that did not have the same stability issues as the original fluid and could stop the proliferation of any current brake system deposits.
Since the recall and the subsequent use of more stable brake fluids, how many of these same type of HCU failures have we heard being reported and how many ABS bikes are out on the road today that have 2+ year old brake fluid that has way more than 3% moisture content and their HCUs arent failing because of brake fluid deposits?
The point being is I think brake fluid flushes are being over-hyped because of the hysteria that was created over the 2018 recall. Just sayin.
For your reading enjoyment:
https://www.alabamainjurylawyer.net/...dson_ABS-1.pdf
Fluid held in ABS unit over time get nasty. gums up the ABS. at first limiting how effective it is. Then causing failure.
At some point it causes damage to the unit that can not be cured by a proper flush.
Only one way to prevent it. A flush with the ABS fully cycled. My Centurion cycles each 60 times.This washes the bad fluid out of ABS unit.
We can debate how often it needs to be done. But it seems HD and others like BMW have decided 2 years is the time line.
You can buy one of several units that cycle the ABS do some home work and do it your self. You can borrow a friends unit to do it.
You can pay HD or an Indy to do it. All that madders is that you do it.
And no taking it out drive fast and making ABS cycle does not get it done..
I've also never had any problems, probably more luck that judgement though
I flushed the brake fluid in my 14 Limited for the first time after the recall, which would have been over 4 years. The fluid has a little darker than new fluid, but there was no gumming in the reservoir and the ABS was, and still is, working as designed.
Im not saying dont flush your brake fluid every two years, but if you dont, waiting three years or even four years, as in my case, isnt going to cause issues with the brakes or the ABS system.
Thanks again.
Thanks again.
They give you a brief description as to why you should buy there product interestingly enough they don't display any data to back it up..... I'll save $179.00 and do it the old fashioned way, IF I feel there is a need to flush the system.
Society today is always looking to make a buck. Don't get me wrong, I'm all about capitalism, but not gonna be sheep at the same time.
