2018+ Softail Models Breakout
Changing Brake Fluid???
Old Apr 26, 2022 | 06:07 AM
sandrooney's Avatar
sandrooney
Default Changing Brake Fluid???
How often should I change the brake fluid in my 18 Heritage? I think I read somewhere every 2 years. Thanks
Old Apr 26, 2022 | 06:28 AM
702's Avatar
702
Two years or sooner if the moisture content exceeds 3%.
Old Apr 26, 2022 | 06:54 AM
tngarren's Avatar
tngarren
I've always assumed bad brake fluid would be a gradual problem, not a catastrophic failure. I've replaced fluid during rebuilds and parts replacements but never just to refresh fluid. 45 years, probably 12 or so bikes/cars/trucks, never an issue.
Old Apr 26, 2022 | 07:04 AM
martin10's Avatar
martin10
Harley has had known issues with their ABS system if the fluid isn't changed. Not sure what year models are affected. I change mine every 24 months per the schedule. You can get some but not all of the fluid out if you do it yourself on ABS bikes.
Old Apr 26, 2022 | 07:45 AM
702's Avatar
702
I've always had the same thoughts as you. But it's more critical now than back in the day. Moisture in the fluid causes corrosion in the ABS pump which leads to failure, and the same corrosion in the master cylinder and calipers leads to lower efficiency. It's worse in high humidity locations, but it's real everywhere. My SGS is 3 years old and the moisture content is under the 3% recommendation so I haven't done the flush yet, but I should - it's pretty dirty.
Old Apr 26, 2022 | 08:00 AM
Steve Sportster's Avatar
Steve Sportster
Get it done. Cheap insurance. Glycol-based brake fluids are hydrofilic (attracts water). DOT 4 is glycol based and it's in your 2018 Heritage system. You should also cycle the ABS system when flushing, per HD. I did mine at 2 years; cost about $180. An Indy shop near me now has the capability to cycle the ABS system (I'm told) and is less expensive. Mine is due again in about 6 months and I plan on getting it done again.
Old Apr 26, 2022 | 08:16 AM
slw210's Avatar
slw210
I would just test it, good brake fluid is good brake fluid. Remove good brake fluid and replace it with good brake fluid makes absolutely no sense.
Old Apr 26, 2022 | 08:21 AM
sevebou63's Avatar
sevebou63
Same here........Never did a total flush.....and no issues. 40 years and many bikes. I think it is over thought. Just another way for HD to get money out of people that don't know better. "If it ain't broke, don't fix it."
Old Apr 26, 2022 | 09:05 AM
smitty901's Avatar
smitty901
Not a Harley issue every motorcycle manufacture requires 2 year ABS flush and requires the system be cycled while doing so..
To answer OP question if you have ABS 2 years. If not test and replace as needed.
Yes you can do it your self many products on the market to cycle ABS.
Old Apr 26, 2022 | 09:08 AM
El Mago's Avatar
El Mago
In my experience, the biggest contributing factor to needing to change brake fluid is the heat I've built up (or haven't) through the type of riding I'm doing. On my Harleys, I've gone 3,4,5 years plus w/o needing to change. On my track bikes, the need to change brake fluid is on a scale of hours spent on the track. Different brake fluids have different boiling points - once it hits that or comes close to it consistently, it really needs to be changed. If I'm never getting close to its boiling point, brake fluid can last a really long time if the system remains sealed.
After a lot of experience, I now only use Motul RBF 660 in all my bikes when I need to do a change.
