2018+ Softail Models Breakout
BCM Light Configurations
Old May 26, 2022 | 07:36 AM
702's Avatar
702
Default BCM Light Configurations
I made a couple of changes to my 22 Heritage this morning. My front aux lights are now always on, either high or low beam - and I also configured the rear turn signals to also be brake lights. If you've ever ridden in Vegas traffic, you know it's good to be seen here. Every road is a race track.
Old May 26, 2022 | 09:11 AM
aviscomi's Avatar
aviscomi
What software/module did you use to achieve this?
Old May 26, 2022 | 09:15 AM
702's Avatar
702
I have the TechnoResearch Centurion Super Pro.
Old May 26, 2022 | 09:16 AM
aviscomi's Avatar
aviscomi
Ah...thanks
Old May 26, 2022 | 02:12 PM
RocketyMan's Avatar
RocketyMan
Cool! Thank you for sharing this. This is good info and tool for whenever "coding" of features is wanted instead of having to use the harley digital tech II.
Old May 26, 2022 | 02:30 PM
702's Avatar
702
I'm going to try do a speedometer correction next. I don't know why, but every HD I've had is off by about 5 mph.
Old May 27, 2022 | 09:47 AM
702's Avatar
702
Oh well, I guess I'll have to do it with a tuner some day.
Old May 27, 2022 | 01:18 PM
RocketyMan's Avatar
RocketyMan
Interesting...does this not show what the current values are? I sure would be interested if there is in fact a difference with softails that have rear tires with a 70 profile vs the 65.
Hopefully a new SW update you can change this, but I assume you can already change this with your '19 model?
Anyway, cool!
Old May 27, 2022 | 02:58 PM
702's Avatar
702
Anyway, cool!
Yeah, I did my Street Glide a while ago with TTS on a dyno. The speedo correction and the idle speed is locked by HD, but can be modified with a tuner. Doesn't make any sense to me.
Old May 27, 2022 | 03:04 PM
RocketyMan's Avatar
RocketyMan
Speed sensor #12 -- 74402-05B
The vehicle speed sensor is in the trans housing. Are you able to look at anything from the ABS module? I'm wondering if that might have wheel size configurations?
