2018+ Softail Models Breakout
Fxlrs 2022 front end bounce
Old Aug 31, 2022 | 03:06 PM
Gimlet's Avatar
Gimlet
Originally Posted by Brian M
Mine does it occasionally but I just chalked it up to bumpy roads and not enough damping in the forks. I’m hoping that when I eventually upgrade the forks it will go away.
Mine can get choppy on bumpy roads. As soon as I bought the bike I felt it lacked damping at both ends, particularly rebound. It could be solved fairly easily without a silly-expensive upgrade, but as it rides perfectly on smooth roads, it's not top of my agenda. Might be when I've cammed it and tuned it with a new exhaust.. I'm used to European supernakeds that can be very harsh on poor surfaces, so the LRS isn't that bad. I think you feel it more because the effect is amplified by the riding position.
Old Aug 31, 2022 | 06:23 PM
natural gasser's Avatar
natural gasser
Originally Posted by Tossy
Problem solved, it originated from the rear wheel and/or tyre
How does the rear make the front bounce?
Old Aug 31, 2022 | 06:29 PM
Tossy's Avatar
Tossy
3rd Gear
no idea, im not a mechanic, rear rim and tyre was changed and it went away.. maybe someone else can answer the question
Old Sep 1, 2022 | 03:14 PM
Brian M's Avatar
Brian M
6th Gear
the rear wheel was replaced? Or was the tire changed and the whole thing balanced?
Old Sep 1, 2022 | 04:28 PM
Tossy's Avatar
Tossy
3rd Gear
both wheel and tire replaced..
Old Sep 2, 2022 | 03:50 AM
Gimlet's Avatar
Gimlet
Should be easy to spot a wheel or tyre that's out of true if you spin it against a pointer with the bike on a stand.
I've had that before with poorly seated tyres.
Old Sep 2, 2022 | 03:12 PM
Bricklayer's Avatar
Bricklayer
Had that with my 2020 FXLR, read of others on here that had the same problem. For me it was the front tire, supposedly a bad band, new front tire, bounce went away.
rauchman
Wheels/Tires
Jul 30, 2020 10:37 AM
19special
The Dark Side
17
Apr 15, 2020 09:36 PM
zrod625
Wheels/Tires
Jun 14, 2019 08:58 PM
NascarGuy
The Dark Side
Apr 11, 2015 04:34 AM
Crazy Canuck
Apr 5, 2006 01:58 AM
