Drivetrain "Compensator"
How did you get so sideways with thread crapping?
Nowhere am I asking any of you to drop trow and brag about some numbers on a piece of paper, be it the dyno sheet, your bill of material for your build, or an accounting of how much money you threw away on it. Pull your pants up and stop dragging your dick. This thread is about drivetrain compensators, not getting sidetracked on someone's parts list for a few more ponies at the rear wheel.
Save that talk for the pit racers BSing at the bar, at the end of race day.
Haven't even had my first cup of coffee this morning after a bitchin 120 mile ride through a nice selection of roads in the Santa Monica Mountains in CA, past Pt Mugu, where the Navy Blue Angels were putting on demonstration flights yesterday. My ancient, slow, POS 2018 Sport Glide with the crummy stock 107 M8 did just fine keeping up with Crazy Hueys stage 2 modded 107 Street Glide, and huffed and puffed a bit keeping up with my other buddies 117 El Diablo. I just got to the next light or stop sign a little slower than them, they had to wait a bit for me. I'd rather enjoy my ride time than race to the next stop, only to sit there and wait, holding in the clutch the whole time.
Retired, life is not a race for me any more, to the last finish line, the coffin. I'm trying to buy time to live a little longer instead.
Actually I did read your 1st post - believe your question was answered shortly after - thus the reason most replies went off topic - i was responding to two gentlemen who "they & I" have opinion differences - not a manhood measuring contest as you imply, The dyno numbers came from an HD dealership who compared the TC to the M8 platform. I didnt post build parts & honestly you asked a question about Compensators and you got answers. if you dont like your comp or are having problems get a new one, if you dont know the workings of a compensator............ Buy a Manual, if you just were looking for the definition of what a Comp does - there are numerous definitions on line explaining it.
Enjoy retirement & glad you made it to the stop sign............ as long as we are all riding what makes the difference if we are on a TC, M8 an Indian, Metric or other! Hopefully you got the answer to your 1st post you were looking for?
Maybe it's because I'm so small and the Softail frame is lighter, that the whole M8 platform feels fast to me, but there's just something about the M8 engine that feels... aggressive.
Something bout it says to me "I aint your grandpa's fat boy, little missy"
Maybe I'm overly anthropomorphizing the bike but it's hard to describe. The M8 Feels like a Harley... but aggressive.
there just isnt a whole lotta compensating for that! LOL!
Not being cruel but whoever built your TC sucked, a stock Freedom 106 Vic will dust off the 107 & hang with a 114.
2016 TC 110 dyno`s at 84.32 Max power & Max torque 98.02 - Out of the Box
2017 M8 114 dyno`s at 85.52 Max Power & Max Torque 109.94 - Out of the box, I dont know............maybe it was sumping, transferring or having a bad day??????
All I can say is you guys must have bought special 114 M8`s, or I got a special 103???? cause stock to stock I run right with that 114 heritage. I dont know............. rode em all - the 107 is not worth the cost to jump up & the 114 is noticeable but still not worth the price of admission. I ride with a small group every now & then who have M8`s some modified - yes those bikes will leave me, but stock to stock - Nope! sad thing is the one guy in the group has a Challenger & he dusts those modded M8`s off & he is stock, .
I figure as long as I can go fast enough to get a speeding ticket thats all I need.
Having owned an airplane, however, I am well aware of how much free power you get having a dual ignition and dual spark plugs on a 100 HP modern fuel injected Light Sport aircraft engine. Under full load of a propeller at 4000 rpm, it was worth 90 to 120 rpm more. Drop an ignition and 4000 rpm dropped to 3890 to 3910, consistently, depending on air temp, air density and relative humidity of the day. Low humidity and high denisity altitude air pressure ( think death valley sea level) add a lot of horsepower, along with a 2nd plug per cylinder. Since aircraft engines take off at full power, and climb at full power, until reaching cruising altitude, it make a big difference in your climb rate in feet per minute, especially as the air gets a lot thinner as you climb.
Think of it like this... on a 100 HP motor with 4 cylinders and 1365ccs, redline at 5800 rpm for no more than 5 minutes, cruise at 5500, 2 valves per cylinder, pushrod driven, silica aluminum bores,no liners of steel, water cooled heads, and piston to cylinder wall clearance of 0.0003" new, from the factory, with a motor rated at 2000 hours of life. It's about a $21000 motor and you get to change it out every 2000 hours. So relatively speaking, how much bigger a HD motor is, it's really not making that much HP or torque, for it's displacement.
The M8, with dual plugs and dual ignition alone, is going to be a much peppier motor than a TC, displacement and cam profiles and compression ratios being equal.
I need to change the air in my tires with some fresh 2023 Globally Warmed Air in my 5 year old Dunlop 407's and 408's. Technology and time keeps marching on. 7200 miles on the set, and the rear tread depth is at 6/32" and change, not even half way worn. Probably get more if I put myself and my bike on a diet. Also put a Saddlemen seat on my bike for more butt dyno torque and horsepower. If I get 12 to 15k miles out of the rear tire, I won't care, ever, what the dyno numbers are. I just don't want the compensator pooping out on me, and knowing how cheap HD is, I wanted to know more about it, some options, and what is better and why, in the drivetrain line.
