2018+ Softail Models Breakout
question about frames
Old Apr 23, 2023 | 07:28 PM
branamoia's Avatar
branamoia
6th Gear
Default question about frames
hey guys does anyone know if all soft tail frames from 2018 and up are structurally the same? I have a 2020 lowrider s that I bought as a project but the more I dig the more I am beginning to think my frame is bent and I honestly am not sure how to go about replacing it threw Harley if that is something they would even do.
Old Apr 24, 2023 | 03:07 AM
Phil13's Avatar
Phil13
Maybe this will answer your questions
Old Apr 24, 2023 | 04:42 AM
SJC69's Avatar
SJC69
The answer is to check the part numbers of the frames, for example in the 2018 parts catalogue there are 4 different frames listed for different models, the extra part numbers are the bearing caps & jiffy stand pad. (1 may just be different as it is Matt not gloss finish.
So I have a 2018 Deluxe and the Frame is #47000126, if I look up a 2020 model on Ronnies H-D parts finder it has the same frame number and also a price!
2018 Parts Book
Now the issue with getting a new frame is going to be is finding a dealer who will supply it, as this is what I understand was the process, the dealer had to verify it with H-D it was a genuine H-D suppled bike and give the frame number, H-D would supply the dealer with a frame & I believe it would be stamped with the original or if not a new suitable frame number.
So a lot of dealers will not do this if they are not doing the work!
Also for a dealer to do it and replace a frame it is normally not cost effective because of the labour costs!
The other option is to have the frame checked by a specialist, here in the UK we used have specialists who had a Motoliner Frame jig that did not require the bike to be fully stripped to check/straighten the frame, far cheaper than replacing the frame if it can be done!
Example of Motorliner service
Old Apr 24, 2023 | 08:55 AM
SJC69's Avatar
SJC69
I believe the link I posted is incorrect!
Motoliner Link
Old Apr 26, 2023 | 11:56 AM
branamoia's Avatar
branamoia
6th Gear
gotcha thanks for the info, seems like ill be calling around an seeing what these dealers are willing to do
Kevinch
Sep 17, 2016 04:58 AM
the Jim in the wolf shirt
Jan 19, 2015 09:14 PM
tpool212
Jul 6, 2011 07:04 PM
jeffwoods1962
Jul 23, 2009 06:14 AM
BuckeyeFanInFL
Ironhead
Oct 30, 2006 03:47 PM
