Modern batteries work all the way up until the point that they die. I dont want the inconvenience of when a battery decides to die. So, I just replace them between 3 & 4 years. Yeah, you might get more life , but where are you gonna be when it goes belly up?
Don't AGM batteries last longer than conventional flooded wet cell? 5-7 years instead of 3-4 years
I get 7 or so out of Harley batteries. but lead acid 4 wheeler batteries last about as long too. Batteries and charging systems have come a long way. My trucks got 8-10 years.
You mean flooded wet cell 4 wheeler batteries? Never heard of those going 8-10 years.
Anything special about Harley batteries? Not overpriced?
I've been getting around 7 years on 4 wheeler. My snowmobile is 2015. My 2010 SXS is on second battery. I over stressed it bunch of short yard trips, and not charging. My 2019 is still factory.
One thing I do is charge before use, so no stressing battery or charging system.
Are harleys better? I don't now know, but I have such good luck with them. And then I come here with people having short lives. Again I am in cooler climate, heat is hard on batteries.
Well, contrary to my previous post, I let the '19 sit for a week without being plugged in and it barely started, so I'll say "four years and a bit" for how long the battery lasted, as it looks like I'll be looking for a new battery soon.
I have an early production M8 softail (07/2017) and retired the HD battery (AGM) at 5y due to age only, for the same reasons others have mentioned. Was still working fine and I at best typically only ever did a monthly maintenance charge with a CTEK 5A smart charger. I typically use the bike once a week for recreational rides only.
I have chosen to replace it with a HD Lithium LIFE battery as a trial and now have a Victron smart charger for Lithium batteries and am following a similar maintenance charge routine for comparison. 12 months on, so far so good 🤞🍻
