2018+ Softail Models Breakout
How do I lube the lower portion of the clutch cable
Old Oct 15, 2023 | 09:49 AM
Candubrain's Avatar
Candubrain
Default How do I lube the lower portion of the clutch cable
With the new fancy clutch cable, how do I lube the lower half?
thanks
brian
Old Oct 15, 2023 | 11:42 AM
nevil's Avatar
nevil
I'm pretty sure those cables have a teflon liner and don't need to be lubed. I don't know what the new fancy cable is about, so maybe someone here can help out with personal experience on that.
Old Oct 15, 2023 | 11:55 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
You dont really need too. You can squirt a bit into the plastic housing down at the bottom, and it'll eventually leak down onto the cable and spread out.
I use TriFlow Lubricant for my clutch cable.
Old Oct 15, 2023 | 11:58 AM
Uncle G.'s Avatar
Uncle G.
The lower half of the clutch cable gets its lubrication from the oil in the transmission. The lower end of the cable housing is connected to the transmission cover below the oil level in the transmission, so the lower end of the cable is submerged in oil.
Old Oct 15, 2023 | 12:09 PM
702's Avatar
702
Yep, and this is what it looks like in there.
Old Oct 15, 2023 | 12:48 PM
TwiZted Biker's Avatar
TwiZted Biker
What these guys have said. I do use Drislide on the cables on both bikes every spring, old habit see no reason to break. Does extend the life a good bit on the old ones.
Old Oct 15, 2023 | 09:32 PM
Candubrain's Avatar
Candubrain
That's great, thank you everyone. I did remove the clutch leaver this year, cleaned it, put a small amount of grease on the pivot points, and lubed the upper section, but I was baffled as to how to do the lower. Well explained and great photo for reference.
propflux01
11
Nov 18, 2023 11:04 AM
gv550
Jul 18, 2023 11:51 AM
Fingas74
Sep 26, 2019 05:42 AM
xskuzame
Oct 6, 2014 09:12 AM
skos
Oct 23, 2008 03:46 PM
