2018+ Softail Models Breakout
Pull Force Scale
Old Mar 16, 2024 | 02:18 AM
SJC69's Avatar
SJC69
Did that very task yesterday, I use a fairly decent and accurate digital suitcase scale and screw driver in the axle as above.
I did get another digital scale with a supposed high hold setting, but this was not as successful or consistent (it rarely set the high hold reading & then need to be reset & put back into hold each time) so as the suitcase scale seemed more accurate it was just as easy to watch the read out and note the highest reading!
So don't overthink it or buy some expensive scales for the task it's a fairly basic operation!
What I have noticed & checked is the table figures have changed considerably from the 2018 & 2019 manuals I have!
Looking at the Part # I assume that is a 2022 manual screen shot!
I'll just add my readings were still within the new range but not by much!
Old Mar 17, 2024 | 10:04 AM
Tozco's Avatar
Tozco
Those ranges are so wide it's a joke. I use a luggage scale but the goal is still smooth operation with no play. If your bike has a gentle weave, you are too tight. If it has any shimmy, wobble or clunking over bumps or sharp braking, you are too loose.
Old Mar 18, 2024 | 11:13 AM
snake_eyes's Avatar
snake_eyes
Yes, what I posted is for '22.
Old Mar 18, 2024 | 01:32 PM
Notgrownup's Avatar
Notgrownup
Suitcase scale
Old Mar 18, 2024 | 01:40 PM
snake_eyes's Avatar
snake_eyes
Old Apr 1, 2024 | 01:51 PM
snake_eyes's Avatar
snake_eyes
As a follow up, I had time to do this check yesterday and the fork head bolt is over torqued from the factory, 9.4lb with a range of 4-8. I always felt like the steering was tight on her bike.
Classic 10
Dec 15, 2023 06:54 AM
lhgdale
Jun 24, 2020 09:24 AM
Tangle Eye
May 20, 2013 05:54 AM
ashmarc
May 4, 2010 11:29 AM
carmencip
Jul 31, 2007 10:36 PM
