2018+ Softail Models Breakout
Faint squeak/chirping under acceleration
Old Apr 7, 2024 | 10:14 AM
stinkerbill's Avatar
stinkerbill
Default Faint squeak/chirping under acceleration
Hi folks
RecentlyI’ve noticed a faint (but more noticeable to me now every time I ride) squeaking/chirping/twittering sound from the bike under acceleration. Seems to be the left-hand side and mid-to-rear… but it’s hard to pinpoint when riding.
At idle/at stand-still, there’s no noise.
If i pull the clutch in and coast along, I ‘think’ it goes away.
Doesn’t seem like it’s the engine (idles fine with no odd noise) or wheels (seems to go if I pull the cutch in), so wondering if maybe it’s something to do with the drive belt?
Any other ideas where I could start looking or maybe think to mention if/when I take it into HD (it’s still under approved/used warranty from when I bought it in Oct)
Old Apr 7, 2024 | 10:45 AM
GalvTexGuy's Avatar
GalvTexGuy
Maybe the belt?
Old Apr 8, 2024 | 06:29 AM
ACE_Moto88's Avatar
ACE_Moto88
Originally Posted by GalvTexGuy
Maybe the belt?
My thinking too. Check your belt tension and make sure it's in spec.
Old Apr 8, 2024 | 12:56 PM
Uncle G.'s Avatar
Uncle G.
Your belt it too tight or too loose. Most likely too tight. I found the recommended specification is too tight and remember, the belt will get tighter as the engine/transmission heats up.
Old Apr 8, 2024 | 01:35 PM
RGS88's Avatar
RGS88
Originally Posted by stinkerbill
Hi folks
Is it throttle dependent? My Road Glide and LRS both made "chirping" sounds from the intake while under throttle, even when cruising with a steady throttle input. Took me a while to figure it out.
It was more noticeable on both bikes when I installed larger/aftermarket air filters
Old Apr 8, 2024 | 02:13 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Similar problem. It was a loose belt guard rubbing the tire. Blew tire at 50 mph. Bit of a thrill.
Old Oct 19, 2024 | 12:15 AM
stinkerbill
Forgot about this post! The dealer adjusted the belt and rear wheel alignment when it was in for a service - no more noise
ipaguy
May 29, 2021 09:36 AM
SetoSeyer
Jul 28, 2020 03:20 PM
rocket50
Jul 26, 2020 10:31 AM
timebandit60185
Jul 15, 2009 10:31 PM
mmgogos
Apr 19, 2008 01:35 AM
