2018+ Softail Models Breakout
Fork-Mount Wind Deflectors?
Old Jul 27, 2024 | 10:58 AM
Beemertrash's Avatar
Beemertrash
I mounted mine on the inside, did not effect my windshield mounts at all.
I used Jess Deflectors.
Old Jul 27, 2024 | 03:02 PM
HarleyHoo's Avatar
HarleyHoo
Mine are the HD fangs like in the photos. The JES ones can be mounted in either location.
Old Aug 1, 2024 | 11:56 AM
don67's Avatar
don67
I recently read an opinion that curved fangs should be positioned to scoop air upwards behind the windshield. Not in front.
The logic is that it relieves the low pressure which pulls in turbulence from above, while shifting updrafts to the shield instead of the tank.
Sure enough, the buffeting reduction of my Amazon cheapie fangs improved significantly when I relocated them higher up the fork with the top edge sitting behind my Windsplitter shield. Previously they were directing air in front of the shield.
Worth a try if your fangs aren't working as expected.
Old Aug 1, 2024 | 04:30 PM
HarleyHoo's Avatar
HarleyHoo
What Amazon cheapy fangs are you using?
Old Aug 2, 2024 | 12:25 AM
don67's Avatar
don67
Amazon Amazon
Old Aug 27, 2024 | 11:00 PM
Number 6's Avatar
Number 6
LTBiker, do you have those mounted backwards.
Shouldn't the curvature scope face forward to catch the wind?
Old Aug 28, 2024 | 02:43 PM
LTBiker's Avatar
LTBiker
[QUOTE=Number 6;21792700]LTBiker, do you have those mounted backwards.
Shouldn't the curvature scope face forward to catch the wind?[/QUOTE
You know, when I first started using these back many years ago, that's what I thought, too. But, if you look at Harley's Parts description with picture for them, this is how they are pictured. Might be interesting to flip them around and see what difference it might make.
Old Aug 28, 2024 | 03:07 PM
gonemad's Avatar
gonemad
He has them mounted correctly. I’ve run them on three touring bikes.
Old Aug 28, 2024 | 03:21 PM
don67's Avatar
don67
[QUOTE=LTBiker;21793358]
I find they work slightly better when curved forward.
Either way, they're effective at reducing turbulent updrafts around the gas tank. But when curved forward, they can also reduce buffeting around the edges of the shield by scooping air upwards behind it thus reducing pressure differentials. I believe this is the main purpose of the curved design; to funnel air into the low pressure zone.
That said, aerodynamics is different in every situation. Everything from rider size to helmet shape can make a difference.
nanook
Jun 26, 2023 09:13 PM
ejvette
Nov 5, 2013 09:18 PM
