2018+ Softail Models Breakout
FXBB digital clock resetting self
Old Jun 4, 2024 | 12:29 PM
Mr.Rabies's Avatar
Mr.Rabies
Lightbulb FXBB digital clock resetting self
hello,
i had set my clock after ownership. since then after every shut off it resets back to 12:00.
battery is new, cables are tight. gauge pod is plugged in stays plugged in.
is this another thing with harley? is this just a trip clock. or is it supposed stay set with powered memory? would be nice to actually use it..
anyone with this issue? what solutions have you found?
the rest of the pod is fine works as it should.
Old Jun 4, 2024 | 01:19 PM
OldMike's Avatar
OldMike
Originally Posted by Mr.Rabies
hello,
Mine stays set, sounds like you have a unique problem.
Old Jun 4, 2024 | 01:23 PM
JimGnitecki's Avatar
JimGnitecki
My 2023 Breakout clock retains time correctly. IF you are not running the bike frequently, there ARE "always on" computer loads that WILL drain the battery within a few days, and thus cause the clock to lose its time. I don't know how many days it takes to run the bttary down on a typical HD, but cars will do it in just a few days. This si why most HD riders keep their bike on a SMART battery charger whenever it is not being used.
Jim G
Old Jun 4, 2024 | 02:16 PM
Mr.Rabies's Avatar
Mr.Rabies
i ride it just about everyday. im going to try again after work.
Old Jun 4, 2024 | 05:23 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I'm not looking at the electrical diagrams, but generally there's two power supplies to the likes of the clock.
One is hot only when the key is on. This is the one that "turns on" the display.
The other is uninterrupted. This is the memory backup function.
I suspect your uninterrupted power supply is not connected. Off hand, I'd suspect a bent pin in a connector.
Old Jun 6, 2024 | 04:36 AM
Phil13's Avatar
Phil13
Try pulling the main fuse for 60 seconds, as in "Have you tried unplugging it and then plugging it back in again"?
Old Jun 6, 2024 | 07:11 AM
Mr.Rabies's Avatar
Mr.Rabies
i had not tried that. i will try.
Old Jun 6, 2024 | 05:24 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Mine resets every time I flash a tune, and I got tired of resetting it so I dont even bother now. It just flashes 12:00 forever lol.
Old Jun 6, 2024 | 05:33 PM
JimGnitecki
Mr. Rabies: FranBunny's posting got me thinking: You don't have any sort of permanently installed tuner on the bike, do you? Because the clock probably does reset anytime the ECU tune is altered.
Jim G
topcat1st
General Topics/Tech Tips
Oct 12, 2021 01:36 PM
JKC
Jul 30, 2012 07:21 PM
Jack Straw
Nov 20, 2010 12:45 PM
MACK
Aug 5, 2008 04:02 PM
cafish
Apr 30, 2007 09:03 AM
