2018+ Softail Models Breakout
Risers with no rise?
Old Oct 24, 2024 | 07:59 PM
Donnie Brasco's Avatar
Donnie Brasco
Default Risers with no rise?
Besides rotating the bars or buying new ones is there a way to get some pullback while keeping the stock display?
Old Oct 25, 2024 | 04:44 AM
Donnie Brasco
I guess I should add that I have a street bob.
Old Oct 25, 2024 | 05:29 AM
luckiestiff's Avatar
luckiestiff
plenty of risers are available with the display cut out in the top clamp
Old Oct 25, 2024 | 12:47 PM
evildiesel's Avatar
evildiesel
pullback top triple tree or a pullback plate will get you pullback without having to change the riser.
the tree is the cleanest and gives no rise, but a lot more money. the plate is cheap but looks kinda chunky and gives about 1" of rise.
this tree is "mymachinist" but thashin supply and original garage both make a pullback top tree.
Old Oct 25, 2024 | 12:59 PM
OldMike's Avatar
OldMike
Be aware that changing the angle of the display might make it unreadable. I can adjust the display angle on mine for best visibility.
Old Oct 26, 2024 | 08:10 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
There are offset plates that you put in between the risers and the steering head. But they will raise the bar by the thickness of the plate itself, usually about 1/2" or so.
jimsreddyna
Dec 10, 2020 12:06 PM
gnstalodz
Dec 17, 2012 06:05 AM
atretes1
Dec 22, 2011 01:55 PM
glideridemike
Aug 5, 2009 08:44 AM
Desertdog
Apr 17, 2008 07:01 PM
