2018+ Softail Models Breakout
Super grabber clamp
Old May 26, 2025 | 11:37 AM
2013superglideseattle's Avatar
Default Super grabber clamp
Anyone else use this clamp on your bike? My bike 2019 heritage.
Old May 26, 2025 | 12:23 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
I've never used that but it looks like it has bite pins in it.
Probably means that before you crank it down you screw down those pins and make bite marks for those pins to sink into.
So make sure you get those bars positioned correctly before you secure down the bite pins.
What I would do is not even install it with those pins in and get my bars and everything setup properly, then crank the bite pins down a bit to make marks on your bars.
Pull the clamp off and for a few seconds use a small drill bit make the marks a little deeper.
Then a tiny dab of blue loctite and torque those pins down.
My foot peg extenders on my crash cage has bite pins like these.
Old May 26, 2025 | 02:13 PM
foxtrapper's Avatar
foxtrapper
It doesn't appear to fit
​​​​​​https://paulyaffeoriginals.com/produ...enter-sections
Old May 26, 2025 | 02:18 PM
Gomer's Avatar
Gomer
Or you could save $89.95 and do what I did and machine .020 off the poorly made standoffs on the bottom of the OEM riser clamps so they grab the handlebars like they are suppose to. Just a thought.
Aitch
Gear and Other Items For Sale
Aug 11, 2023 08:28 PM
KissMyDrums
20
Sep 11, 2021 03:43 PM
kenwood
Aug 19, 2020 08:43 PM
Curated Content Editor
National Events
Jan 25, 2017 03:15 PM
