2018+ Softail Models Breakout
Almost ready to mod :)
Old Jun 6, 2025 | 02:41 PM
evildiesel's Avatar
evildiesel
solid parts list, thing should rip and sound like a whole new animal.
Old Jun 6, 2025 | 02:50 PM
cobra23's Avatar
cobra23
With the extra power, there is more stress on the stock cast compensator ramp. These have been known to fragment in both stock and higher power motors, which would definitely ruin your day.
Going to a billet ramp is worth it for the peace of mind.
Old Jun 6, 2025 | 03:30 PM
chunks's Avatar
chunks
i can see that. looks like ill need a new torque wrench as well to install it and a breaker bar to remove it. That big-*** nut calls for 175 ft-lb and mine only goes to 150...
Bonus: new tools!
Old Jun 6, 2025 | 06:12 PM
chunks's Avatar
chunks
Peace of mind has been purchased
S&S Compensator Ramp added to the list, along with S&S 55mm CNC Ported Intake Manifold, and Fuel Moto 5.5 Fuel Injectors
Along with all the other stuff, my wallet hurts
added
Old Jun 6, 2025 | 06:14 PM
chunks's Avatar
chunks
The job is shaping up into a full weekend of work at this point.
Old Jun 7, 2025 | 01:56 PM
cobra23's Avatar
cobra23
You won't regret adding the extra parts.
Ride safe
Old Jun 8, 2025 | 08:39 PM
Biggzed's Avatar
Biggzed
The more aggressive the lope at idle the harder it is on the comp as well. The lope (or chop as the kids call it) basically loads and unloads the comp and will wear out the parts much quicker. When I installed the CR480 in my 114" the comp immediately started to make noise. It would have been replaced this winter had I not totaled the bike.
Zach
Old Jun 9, 2025 | 08:41 AM
chunks's Avatar
chunks
Zach
Well it should be a non-issue now. Thanks!
This part (S&S compensator ramp) at least I can install as soon as it (and primary gasket) arrives. I have all necessary tools. Unless I'm tripping this part wouldn't require any adjustment to the tuning
Everything else has to wait 3 or 4 weeks will the PV4 arrives.
Waiting Real Feel temp: 3-4 weeks = 47 years
Old Jun 9, 2025 | 09:45 AM
rigidthumper's Avatar
rigidthumper
Return the S&S manifold and FM injectors. Don't need, wont fit your 25.
Old Jun 9, 2025 | 07:42 PM
chunks's Avatar
chunks
Well, "need" is a subjective thing. Will it run without them? Most likely. I did read many convincing arguments that indicate that with a high lift cam and the other mods, it will likely run better with them and further improve performance
Not sure why you would say they wont fit. Almost everywhere I look it says both these parts will fit. J&P Cycles, Revzilla, Parts Giant, Fuel Moto, and several others.
Haven't found one site that says they wont fit.
