2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Tire sensor issue
Old Nov 3, 2024 | 04:10 PM
  #31
Spider3223's Avatar
Spider3223
My issue is it is actually reading the pressure wrong, it says 32 in the front tire and 34 in the rear, when I check it the pressure is correct 36 in front and 40 in rear. So I actually think my sensor is off. Dealer put air in and reset the computer and sure enough it’s back on. This will be the third time I bring it back, most likely I’ll just wait until I need new tires to save a trip.
Old Nov 3, 2024 | 09:31 PM
  #32
hairymoth's Avatar
hairymoth
My TPS system is a couple of lbs off on the front tire and pretty and close on the rear. I don't care. The real value of the TPS is that it will alert you to a change in pressure when something is wrong. When that happens, I am use an accurate gauge to get a more accurate reading. Accuracy in tires is fleeting anyway. The pressure changes, from before you start your bike up, till you've gone sixty miles, at highway speeds on a hot day, by about 6 lbs. +/- 3 lbs in the TPS is nothing to worry about, just get to know the characteristics and you will be fine.
Old Nov 4, 2024 | 09:59 AM
  #33
mjwebb's Avatar
mjwebb
well said
cdremy
General Topics/Tech Tips
18
Jun 13, 2024 07:57 PM
aviscomi
Pan America
Aug 11, 2021 08:58 PM
transman
Jun 20, 2021 07:26 PM
RinTin
Screamin Eagle CVO Models
Sep 4, 2018 12:28 PM
Watchfuliz
2014-2024 Touring Models
Oct 1, 2015 08:01 AM
