Curious what is a "normal" engine temp range at idle after the motor has been warmed up (not riden). RG has not been started in about over a month, about 5 minutes after start up I hear the engine fan kick on. Checked the engine temp and it was back and forth from 185-192, I would think these temps would be caused from a hard ride but not at idle. Is this something I should be concerned about?
no you shouldnt, stop looking at it and ride.. be more concerned about your turkey internal temp being at least 165 today
It's normal.. The engine is air and liquid cooled. So you're going to see a bit of extra heat when there's no air movement over the cylinder cooling fins.
Depends where you are measuring the temperature. You need at least 212 oil temp to cook off moisture. Some will say nominal oil temp is 235. I’ve run mine at high speed (90 mph ish) in 114 degree desert heat for several hours. I was roasted, and the glue holding together my plastic Ciro water holder melted, but the bike ran fine..,and did for many thousands of miles later.
Air cooled motors are not like thermostatically regulated water cooled engines, and as such their operating temperature varies. Also, as a reminder your bike has a wet head. It is designed to cool just the area around the exhaust valves to reduce heat to the rider…it has very little impact on operating temperature.
Depends where you are measuring the temperature. You need at least 212 oil temp to cook off moisture. Some will say nominal oil temp is 235. Ive run mine at high speed (90 mph ish) in 114 degree desert heat for several hours. I was roasted, and the glue holding together my plastic Ciro water holder melted, but the bike ran fine..,and did for many thousands of miles later.
Air cooled motors are not like thermostatically regulated water cooled engines, and as such their operating temperature varies. Also, as a reminder your bike has a wet head. It is designed to cool just the area around the exhaust valves to reduce heat to the riderit has very little impact on operating temperature.
Harley began boasting about reduced engine temperatures when they introduced the M8s new cooling systems not only to improve rider comfort
"A Milwaukee 8 engine utilizes oil cooling to reduce engine temperature by circulating engine oil around critical components like the pistons and cylinder walls, effectively absorbing heat and transferring it to the engine's oil cooler, thereby lowering the overall operating temperature of the engine."
"Improved efficiency:
By effectively managing engine temperature, oil cooling enhances engine performance, longevity, and reduces the risk of engine damage from excessive heat. To deal with the heat issue, Harley reduced the exhaust gas temperature by 100°F (55.6 C) by introducing a better water cooling solution."
Have 0 worry. Yesterday I got stuck in traffic for 2 hrs, midday tropical country 100F+. Barely felt anything on engine side, primary cover was the hottest point... No knocking upon traffic opening up. If my memory is correct, I would say this is even cooler than carbed hi comp Evo engine. Mine's fully decatted though..
That is nothing to be worried about. Normal behavior according to the owners manual.
The radiator fan kicks on at around 180F.
When I rode the other day it was 41F and I rode 75mph for 35 minutes straight. Engine temp on the display was 215F. When I ride the same route at 105F, engine temp is 243F. According to the service manual these are normal engine temps.
If you let your bike idle long enough temps will exceed 240F as the fan will not pull enough air to keep the coolant cool enough to keep the engine cool enough. Don’t do that.
If you let your bike idle long enough temps will exceed 240F as the fan will not pull enough air to keep the coolant cool enough to keep the engine cool enough. Dont do that.
I have no doubt that 243F is considered an acceptable temperature, but it just sounds so high. Thats a tough thing to get used to.
I agree that its best to just not even look at the temp.
Cant argue with fact, no matter how we feel about it.
Thats just the engine temp. Head temps are usually around 300F and the oil temp is somewhere in between. Since the 24 models have added some minor liquid cooling, these temps are cooler than the Gen1 2017-2023 M8 engines.
i was thinking the op was suggesting he was discussing the wet head, since he talked about the engine fan. That lead me to believe he was referring to the radiator fans, which are there for the wet head. And my comments pertained only to the wet head, which preceded the M8. I made too many assumptions.
