2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
buffetting/shaking.
Old Aug 2, 2025 | 08:58 PM
paud's Avatar
paud
Default buffetting/shaking.
Ideas on what would cause my '24 Road Glide to have front end shake/buffeting increase as speed increases, from 60 mph and up.
I have had it to the dealers several times, and the most they found was a right front brake rotor out of spec. I have put 200 miles on the bike since then.
2 different dealers have ruled out brake issues. One dealer thinks maybe suspension issues. I know its not just a helmet buffeting thing because at 80 mph, I duck my head far enough behind the windshield so I feel no wind, making sure its not just my helmet moving.
Any thoughts or ideas or speculation is welcome at this point.
thanks...
Old Aug 2, 2025 | 10:52 PM
mjwebb's Avatar
mjwebb
thanks...
I had a brand new faulty Dunlop installed once that exhibited that behavior immediately after install..the front end was doing the Watusi on me beginning around 70 mph..they replaced the tire and it instantly returned to being as stable as a slot car ... or maybe it could just need rebalancing
Old Aug 3, 2025 | 05:12 PM
paud's Avatar
paud
The tire is ballance and after 900 miles I can not see anything wrong with the tire. HOWever, I do have plans, when I save some $$$ to replace the front tire. 2 different dealerships have said nothing is wrong.
Old Aug 5, 2025 | 10:27 PM
Hondo95's Avatar
Hondo95
Default Tire mounted wrong
I had a 2020 FXLRS and it would do the same thing. I took it to the HD dealer and they couldn’t figure it out. I then took it to a Indy shop and the mechanic took the tire off the rim, installed it and balanced the tire. The problem was solved. Good luck.
Old Aug 6, 2025 | 05:35 AM
Neanderthaler's Avatar
Neanderthaler
What windscreen do you have? I saw a Travelling Tall video on YouTube where he had the same problem (at the drag strip). He removed the windscreen and the problem went away. My 24 is perfectly stable up to the limiter with a Klockwerks
jmio
Mar 12, 2015 05:21 AM
skully1200
Sep 25, 2012 10:46 AM
Wally
Jun 7, 2010 10:29 PM
Maccam26
Sep 10, 2007 11:08 PM
billk
Sep 7, 2006 12:30 AM
