Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Arnott Introduces Handlebar-Mounted Pushbutton Controller with LED Pressure Gauge
Old Sep 29, 2017 | 01:07 PM
ArnottDoug's Avatar
ArnottDoug
Former Sponsor
Default Arnott Introduces Handlebar-Mounted Pushbutton Controller with LED Pressure Gauge
Arnott Motorcycle Air Suspension -- the leader in True Onboard Adjustable Air Suspension kits for motorcycles -- announces the introduction of a handlebar-mounted two-button switch with digital display designed to enable riders to quickly adjust Arnott Motorcycle Air Suspension Shocks and easily see the pressure value in pounds per square inch (PSI).
The waterproof assembly mounts to the handlebar clutch perch and has separate buttons to inflate or deflate the air suspension system and a blue LED air pressure display.
The black inflation kit, K-3114, comes complete with a high-impact aluminum housing finished in black Type III Hard Anodization, which is completely sealed off from outside elements.
The chrome inflation kit, K-3115, comes complete with a high-impact aluminum housing finished in chrome, which is completely sealed off from outside elements.
The switch includes an attached wiring harness pre-configured with the necessary connectors. The kit also includes a pressure transducer which attaches to the Arnott manifold, additional tubing, airline fittings, spade connectors and wire taps for connecting the unit to the motorcycle's ignition switch wire.
K-3114 and K-3115 retail for $299 each and are backed by Arnott's Limited 1-Year Warranty.
Hacksaw550
2014-2024 Touring Models
Jan 23, 2019 11:35 AM
LilWick
69
May 27, 2018 09:41 AM
slammed05fatty
Mar 14, 2015 11:36 AM
RickK
Apr 30, 2014 01:42 PM
YtseJam
Jan 26, 2010 07:15 PM
