Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
lowering kit
Old Mar 17, 2012 | 09:28 PM
FLIP72's Avatar
FLIP72
2nd Gear
Default lowering kit
Dont know if I'm in the right section,but I have a 2009 street glide. just removed rear air susp. installed new BURLY Slammer kit in frt & rear. looks real good. Dropped it about 2". have one little problem,since this is a 2009 with redesigned frame & swing arm. the left side of swing arm just hits the end of frame. If I adjust rear spring to be stiffer,it make bike high,that would be a waste of having lowering kit.Had to grind away frame end abit. Has anyone needed to do that. Iknow on the 2006-08,there is no need to grind>
buggy
Touring Parts
Sep 15, 2011 01:23 PM
deeblues
Aug 8, 2011 11:28 PM
Jtreer
Mar 19, 2011 02:34 AM
FLH05
Feb 26, 2009 10:58 PM
CLL375
Apr 23, 2007 10:02 PM
