Fuse location
Old Sep 23, 2014 | 08:34 PM
1HD2NV's Avatar
1HD2NV
Default Fuse location
When I wired my 2180 I placed the power wire in-line fuse toward the battery end, probably 6" from, for ease of service. Any reason, beside personal preference, that this is incorrect or that it should be a certain distance from the amp?
Also, since the 2180 comes with 14AWG I went with that for both power & ground (to battery). Not sure anything bigger would fit in amp terminal. Anyone ran bigger with BT amp, or who believes this is not sufficient?
Have had a few issues that have me reviewing everything...
Appreciate the feedback.
Old Sep 23, 2014 | 08:41 PM
tdgriff's Avatar
tdgriff
I just talked to Bill about this yesterday and he told me the wire they use is just fine. He said the BT amps are so efficient they do not need any bigger wire.
Old Sep 23, 2014 | 08:52 PM
tdgriff's Avatar
tdgriff
Just looked into the fuse not a bad place at all that's the place mine is . your good why the worry?
Old Sep 24, 2014 | 02:34 PM
1HD2NV's Avatar
1HD2NV
Have had some issues with amps, and blown fuses. BT is awesome as usual but thought I could get some input from others here. Assume everyone is using a fused link, but obviously not wanting to comment.
Old Sep 24, 2014 | 05:01 PM
tdgriff's Avatar
tdgriff
How did you wire your amp?
brschmidt
Aug 19, 2022 11:50 AM
kryingame
Audio Systems
Aug 10, 2014 07:27 PM
Cyclemedic69
Aug 15, 2010 08:46 AM
Cyclemedic69
Aug 14, 2010 09:45 AM
Lemms
Feb 25, 2010 05:39 AM
