Nav System Question
Old Oct 21, 2014 | 08:48 PM
wijr1949's Avatar
wijr1949
Default Nav System Question
My 2011 TriGlide does not have the Nav system installed.
How big of a deal is it to have it installed and is it worth it?
I really don't want to have to mount my Garmin and find a way to power it and all that BS.
But I would like to have the Nav system so what are my options and, if known, associated costs?
Thanks.
Old Oct 22, 2014 | 07:57 AM
hd_rolling's Avatar
hd_rolling
If you can remove your outer fairing its really not difficult to wire for power at all. I'm a big fan of the mount I use, it puts the Garmin right below your line of sight so you have your eyes off the road as little as possible. Its quicker to look here than your speedometer. They sell for about $50 on ebay
http://www.ebay.com/itm/Harley-David...c22a8f&vxp=mtr
Old Oct 22, 2014 | 09:14 AM
UltraNutZ's Avatar
UltraNutZ
Thanks.
are you referring to the NAV system that can be installed in the HD stock head unit/radio? If so;
1. you'll be hard pressed to find one
2. they aren't worth a crap and you can't see the maps on the small display
If you're referring to aftermarket products, sky is pretty much the limit on mounting and wiring. if your garmin is a 660 or 665 model you can get the wiring kit and fairing mounting kit so the device is not mounted to your handlebars but instead on the top left of the fairing itself and everything is hidden (wiring)
Old Oct 23, 2014 | 08:37 PM
wijr1949's Avatar
wijr1949
I have a garmin nuvi 1450 that I would like to continue to use, if possible.
Do you have a link to find the mounting kit you mentioned?
Thanks.
Weldon.
Old Oct 23, 2014 | 09:51 PM
hd_rolling's Avatar
hd_rolling
Thanks.
Weldon.
The mounting kit he's referring to you can use to mount a nav but you need a Harley road tech version to make it work through your speakers.
Old Oct 24, 2014 | 12:08 PM
wijr1949's Avatar
wijr1949
Thanks for all your help and information.
I'm very new to Harley-Davidson and my learning curve is straight up for now.
Old Oct 24, 2014 | 01:15 PM
UltraNutZ's Avatar
UltraNutZ
hd_rolling has you covered there. In addition, the fairing mounted bracket I was referring to is only used on the Garmin 660 and 665 and then the HD version of those units, Roadtech 660 and Roadtech 665.
Ram mount has a TON of options for you to mount your GPS whether it be fairing, handlebars, etc. Check them out.
Estil
Aug 22, 2016 03:37 PM
Talldog
Sep 10, 2013 03:16 PM
Motown_HOG
Apr 29, 2013 01:05 AM
my06uc
Jun 19, 2006 01:17 AM
zubaugh
Jan 20, 2006 11:01 PM
