? on setting gains using a DMM
Old Dec 8, 2014 | 11:20 AM
Little Mike's Avatar
Little Mike
Default ? on setting gains using a DMM
2) Turn all equalizer settings, bass boost, etc. on HU to their minimum settings
Could someone clarify if this means all levels set to FLAT or all the way turned down which would be a negative value? Thanks
Old Dec 8, 2014 | 11:59 AM
dirtracin23's Avatar
dirtracin23
The way I read UN sticky is, when using a DMM to set gain, turn all values to their minumum settings.
"2) Turn all equalizer settings, bass boost, etc. on HU to their minimum settings
3) Turn volume control all the way down on HU
4) Turn all gain controls, bass boost, etc. on amplifier to their minimum settings"
When setting gain by ear, set them to flat on stock HK head unit.
"On stock H/K- Harley head units set your bass and treble to flat settings. Flat is the middle smaller bar on the display
On aftermarket head units, the easiest thing to do is press the reset button on the head unit to reset everything on it back to factory defaults. Otherwise make sure bass, treble, and ANY other sound enhancements are turned to their 0 settings".
I'm sure he will chime in on this for clarification.
Old Dec 8, 2014 | 01:27 PM
AAWAV's Avatar
AAWAV
minimum is flat, no matter what.
so EQ or Low/Mid/High all to the "middle / zero" setting, not negative -12 or -10Db, all to zero or 0Db.
that way you have the ability to decrease / increase freq's...
my 2 cents
cfave
Audio Systems
Apr 21, 2018 03:34 PM
Makdaddy
Audio Systems
19
Sep 13, 2017 04:43 PM
stro1965
2014-2024 Touring Models
Oct 20, 2016 12:04 PM
Jim NT
Audio Systems
Jun 5, 2016 09:54 PM
Jags93
Aug 15, 2010 05:40 PM
