Infinity Kappa 62.11i
Old Dec 14, 2014 | 10:13 PM
bowhuntenbob's Avatar
bowhuntenbob
Race thanks for the picture I guess I was looking at the wrong photos when I put them in..
Old Dec 14, 2014 | 10:30 PM
SBates08's Avatar
SBates08
You get it figured out?
2010 Limited with some stuff!!
Old Dec 15, 2014 | 04:56 AM
bowhuntenbob
Gave it a rest last night will look at it tomorrow night if I have time.
Old Jan 6, 2015 | 08:11 PM
dibe's Avatar
dibe
Did you ever get this figured out?
The kappas for my rear pods will be here tomorrow so I plan on doing the install soon.
Also, did you mount the speakers on top of the pod or take the pod off and mount it on the inside? I have been searching for this answer but can't seem to find much on it. Thanks.
Old Jan 8, 2015 | 10:25 AM
dibe's Avatar
dibe
If anyone comes across this and is wondering about it. I mounted the speakers on the outside. It doesn't look like there would be enough room on the inside, at least on my 08.
I also took the extra brackets that came with the speaks, cut of the extra tabs, and used those as spacers on the back of the speaker as the speakers were a little too big to sit down all the way in the pods.
Old Jan 8, 2015 | 11:33 AM
SBates08's Avatar
SBates08
Originally Posted by dibe
If anyone comes across this and is wondering about it. I mounted the speakers on the outside. It doesn't look like there would be enough room on the inside, at least on my 08. I also took the extra brackets that came with the speaks, cut of the extra tabs, and used those as spacers on the back of the speaker as the speakers were a little too big to sit down all the way in the pods.
Any speaker that you would mount in the rear pods would be mounted from the outside. My Infinitys wouldn't fit without the spacers either. Don't really understand how some will fit and some won't.
Old Jan 12, 2015 | 08:14 AM
SmittyFXDL's Avatar
SmittyFXDL
I ordered Infinity Kappas for fairing speakers and they should be in today or tomorrow. Was wondering if anyone tried fitting them in fairing with their grills and if any mods where needed to make em fit?
Old Jan 12, 2015 | 12:49 PM
Gannicus's Avatar
Gannicus
No mods with the exception of speaker adaptors Anthony. . Use the stock grills.
Old Jan 12, 2015 | 12:59 PM
dibe's Avatar
dibe
Anything is possible I suppose. You could probably get the grills in there with some modifications to them. I believe most of the guys just run the stock Harley grill up front.
Old Jan 13, 2015 | 03:22 PM
SmittyFXDL's Avatar
SmittyFXDL
Yeah just used stock grills. Man I like them kappa grills though. Pretty sweet speaker setup so far. Hope they are more reliable then the polk audio mm651's.
