Opinions needed on this setup
Old Jan 18, 2015 | 09:41 PM
Little Mike's Avatar
Little Mike
What year and model is your bike? The ignition switch wiring harness on early to mid 2000 model year touring bikes runs from the switch to a 4 place packard connector that mounts right under the radio. If you disturbed that connector or the wires were somehow damaged or compromised during the amp install then that could be the problem.
Old Jan 19, 2015 | 06:24 AM
Gooey2's Avatar
Gooey2
OK for my 2 cents I would plan ahead , a 4channel amp BT AVC module for most stereo. What sounds great now will be replaced or expanded.Good luck!
Old Jan 19, 2015 | 09:44 AM
Ganooch's Avatar
Ganooch
Thank you for all of the advice. Maybe a four channel amp would be better in case I want to do lids in the future. What amp would you recommend for the 2015 RG? Biketronics is pretty pricey stuff.
Old Jan 19, 2015 | 01:18 PM
dirtracin23's Avatar
dirtracin23
Are you sure he needs speaker adapters on the 2015? I didn't but mine is a RGS. You will probably run into clearance issues with the stock speaker grilles. At least I did with the Infinity Kappa 62.11i.
You will also have to figure out some way to mount your amp as the only place there is room for one in the fairing (at least on a RGS) is under the factory HU. IDK if there is room on top of the HU on the standard RG with the 4.3.
Old Jan 19, 2015 | 03:06 PM
tdgriff's Avatar
tdgriff
Yes it is but well worth it. Lifetime warranty no questions asked. Plus you can call Bill and he will walk you threw the set up if you need it. He will not sell you crap you do not need. Very stand up company.
Old Jan 21, 2015 | 12:27 AM
JMJOHN's Avatar
JMJOHN
Sponsor
with this amp kit http://www.jmcorp.com/ProductDetail....AA-3600HR15-RC ,,,,, these fairing speakers http://www.jmcorp.com/ProductDetail....RRK-6652TW-RXX and these saddlebag lid speakers, http://www.jmcorp.com/ProductDetail....ID=HSDR-5X7-14 I can enjoy the stereo on my new 2015 RoadGlide as fast as it is capable of traveling,,,,,, ((somewhere just over 100)),,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Jan 21, 2015 | 05:09 AM
just plain john's Avatar
just plain john
Soundstream 520 or Power Akoustic RZ2000D, but either one will kill FM reception.
Old Jan 21, 2015 | 09:22 AM
scumBAGGER's Avatar
scumBAGGER
5 by 7 in the bags? guy I ride with has 5by7 and they are junk sound like crap and he blew them 2 times now.....I believe they are Hogtunes is a 5by7 even a good speaker? why not go 6by9 if your investing that kind of cash?
Old Jan 21, 2015 | 10:34 AM
AAWAV's Avatar
AAWAV
not per definition! it is a hit or miss or partial hit/miss...
RZ4 recently (re)tested out to 140W RMS per channel @ 2 ohm / 100W at 4 ohm on my bench. Bike running...
Little Mike
Audio Systems
136
Mar 5, 2026 07:59 PM
sunnenman
Audio Systems
17
Apr 3, 2016 08:44 PM
Highwayman-AL
Audio Systems
15
Jan 29, 2015 06:36 AM
r8rs4lf
Jul 15, 2010 07:18 PM
krom nutz
Jul 1, 2009 09:44 AM
