Could be so simple with the right stuff
ok all, i need some help finding a 4 pin AMP Multilock plug! im wiring up 2 PBR 300x2 amps. 1 for the rear speakers and 1 for the front speakers. I want to(or hope to) avoid cutting, splicing, soldering, and heat shrinking all the wires.lets talk about hooking up the rear amp only though as the process will be the same for the front. what i "want" to do is unpin the 1,2,24,25 sockets from the 35 pin plug and place them into a 4 pin plug(to be used in a bit). Then crimp the same style and size socket pins on the input wires leading to the amp and plug them into the 35 pin plug(1,2,24,25). Hope this all makes sense!! Then if i can find the Pins to crimp onto the speaker output wires coming out of the amp and place them into a plug that will connect to the plug that has the 4 sockets that i originally removed from the 35 pin AMP plug. ugh! hope thats understandible! lol So mainly im looking for the 4 pin AMP multilock plug that will accept the factory sockets that i removed from the 35 pin plug!
NM-33472-0401 4-Position Female OEM# 72177-07BK $1.89 x2
Molex Connector Pins & Sockets (16-20 gauge)
Male terminal pins (repl. OEM #72169-07) x8
Female terminal sockets (repl. OEM #72168-07) x8
For the 35 pin connector Female Crimp Terminals, (HD# 72381-98) (50pk)
