Replacing Speakers
Old Feb 19, 2015 | 06:01 AM
Londonbike's Avatar
Londonbike
Default Replacing Speakers
How difficult is it to change front speakers on a 2014 Ultra Limited? Mechanic at dealer said to pull radio cause some screws are near impossible to remove with radio in way. Service manual does not discuss removing radio. Any thoughts to help me on this?
Old Feb 19, 2015 | 10:11 AM
TriGeezer's Avatar
TriGeezer
Would you not change the speakers if you had to pull the radio?? If not, go forward and prepare to have to pull the radio. If pulling the radio would keep you from doing the speakers...then consider pulling the front fairing to check out access to the speakers. Lots of info in here on pulling the front fairing.
Good luck.
Old Feb 19, 2015 | 07:46 PM
z71_fourwheelin's Avatar
z71_fourwheelin
There is a write-up somewhere in this forum. There is three 7/16" bolts per side with that are a pain but can be done. I removed them in 5 minutes
Timmy B
Feb 12, 2014 08:13 PM
Bonzaiii
Audio Systems
Oct 22, 2012 07:19 AM
bandit5001
Feb 26, 2012 09:14 PM
DellaPia
Jun 28, 2011 02:17 PM
Candy Red Road Glide
Jul 8, 2007 11:31 PM
