Has anyone seen or heard this new DUAL amp, or have you already bought and installed this amp.
The specs seem pretty great for this size amp. At $269.00
DA1504D Power Output (14.4VDC, 20Hz ~ 20kHz@4ohms): 250 Watts x 4 channels @ 4Ohms 480 Watts x 4 channels @ 2Ohms • 900 Watts x 2 channels @ 4Ohms (bridged)
Peak Music Power Output:3000 Watts
Signal to noise ratio:> 80dB (THD < 0.5% @ 4Ω, 14.4V)
Frequency response: 10Hz– 35kHz (-3dB) A Amplifier dimensions: 1.6” x 4.7” x 10.2” (40 x 120 x 260 mm)
Seems like great specs. Should fit in the fairing. Batwing the is.I cannot find enough specs on it. We need to get this one on the bench... IMHO the specs are overrated but we will not be for sure until it has been tested.
I've sent them an email trying to find out when it's available retail, all i can find out so far is that it is shipping January 2015.
Nutz doesn't like the 80dB rating but the PA RZ4-2000d and SS PN4.520D are only 70dB rating, now the CV B4 is outstanding at 101.1dBa at least according to their website.
