Hey all,
I picked up a 2001 Electra Glide last year and it looks as if it never had a radio to begin with. I do have the audio controls on the handlebars for it, I am wondering of a radio from a 2006 road glide would plug and play with the 01? I am basically illiterate when it comes to electronics. DO I need to pull the fairing apart to see if it has the wiring? Any help is appreciated.
In 2006, the radios changed quite a bit. The size and mounting brackets are different between 2005-2006. Then the Road Glide has different brackets from the EG.
The Ohms ratings changed in 2006 also. You want to match the speakers to the radio in Ohms ratings so the speakers don't overload the radio. The exception to this is if you add an amp, then the speakers should match the amp output's Ohm ratings.
I'd pull the outer fairing and see if the wiring is there first. It should be. Once you verified that, then you can start looking for a radio that fits and matching speakers.
Michael, I have a friend that has a 2002 Electraglide stock radio for sale. It will work with your control just fine. PM me for details if interested? . Doug
[QUOTE=HCC Cycles;13738648]In 2006, the radios changed quite a bit. The size and mounting brackets are different between 2005-2006. Then the Road Glide has different brackets from the EG.
I'd pull the outer fairing and see if the wiring is there first. It should be. Once you verified that, then you can start looking for a radio that fits and matching speakers.[/QUOTE
You are right sir...06 was the first year for HK's and HD put better heads that year.
Thanks...I will pull the outer fairing and see what working is there. ..good place to start.
Its a white module male end. I have my fairing off right now...waiting on 4180 and gauges. So I can post you pix tonite after work. Hey mike, my buddy has some J&M's 2 ohms speakers for sale too. I pm'd you with details. Doug.
I'm assuming your bike is a 01 Electraglide Standard?
