2003 flhtc audio upgrade
Old Mar 10, 2015 | 08:19 AM
rkidd's Avatar
rkidd
Default 2003 flhtc audio upgrade
I am currently running stock hu on my 2003 flhtc. 3 years ago I replaced stock speakers in fairing with 5,25 hogtunes and added 5.25 hogtune speakers to my newly installed lowers with their 2 channel amp running the speakers in the lowers. It was a big improvement and way better than stock. After looking thru this section I am thinking about going up a level. I want to keep stock hu and keep fm reception. Not looking for a top of the line system but a better one. I was considering 4- t165 Rockford fosgate speakers. 2 in fairing 2 in lowers. On the amp not sure due to limited audio knowledge if the pbr 300x2 wired in parallel or the pbr 300x4. Last thing is the hogtunes came with the adapter for 5.25 speakers for the lowers. What will it take to mount 6.5 in the lowers now. Your guys input would be appreciated. Thanks in advance.
Old Mar 10, 2015 | 11:14 AM
duglaura&flhti's Avatar
duglaura&flhti
Default up
Good choices Rkidd.....you might need speakers adapters rings for the speakers upgrade. I went from a 2 channel amp to 4 channel for the reason of 4 hi output speaks...Your keeping the old radio sound HU....if you can pull it, pinch it out....old stuff man. There so many aftermarket HU that's does everything. Cost is a issue, talk to Bill at Biketronics he can work put together a package for your specific system....Good luck.D.
rkidd
Audio Systems
59
Apr 21, 2019 06:49 PM
cskarns
Audio Systems
Mar 9, 2019 07:34 AM
Mcarso1
Audio Systems
May 8, 2015 03:17 PM
maverick2076
Audio Systems
38
Nov 29, 2014 08:04 PM
jjpish
May 19, 2012 08:28 AM
