Saddlebag speaker adjustment (how to increase???)
Old Apr 2, 2015 | 09:54 PM
shredsurf's Avatar
shredsurf
Default Saddlebag speaker adjustment (how to increase???)
While messing around with the audio toggle switch (left side) I somehow brought up a screen that showed the "F" and "R" with the volume rectangles next to each.
The "F" was set at around 8 to 10 while the rear was set around 4. I was only able to adjust the "F" using the left toggle. I was unable to adjust the "R".
My questions...how do I get that screen to show up again and how and where do I adjust the "R"?!??!
Old Apr 2, 2015 | 10:30 PM
Crimson's Avatar
Crimson
Sounds to me like you had the headset adjustment up not the speaker adjustment. The Front/Rear adjustment for the speakers (Assuming stock HU) doesn't show separate values for the front and the rear, you just fade between front and rear..
The screen you saw was for the headset volumes.. unplug any headsets you have and you should get the normal F/R slider for speakers. Check your speaker switch setting as well to make sure its in the right position for what you are trying to do.
Old Apr 4, 2015 | 08:26 AM
shredsurf's Avatar
shredsurf
Sounds like a plan, thanks for the insight.
HD REBEL
Audio Systems
May 11, 2015 11:24 PM
bcane98
Apr 2, 2013 05:51 PM
MasterGunz1775
Dec 20, 2012 08:30 PM
Classic bagger
Nov 28, 2012 07:18 AM
