HELP - No Power
Old Apr 10, 2015 | 02:33 PM
BOSOXFan's Avatar
BOSOXFan
Default HELP - No Power
Assuming hooked up he ASWC-1 correctly because I get lights on it. the issue I am having is not power to stereo nothing, notta, Zip Zilch.
I a using Sony DSX-S210X head unit and Punch PBR300X4 amp. Maybe a grounding issue? I grounded the pink/white wire coming from handle bars to the male tab on the triple tree ground. The AMP and stereo are also grounded to the same bolt (loosened bolt and both wires are sharing a "U" crimp connection.
Yellow to yellow
orange and red from stereo to red on ASWC-1.
on the AMP I only hooked up front RCA plug and the front stereo plug.
that should be all the connections..... IDEAS???
Old Apr 10, 2015 | 02:50 PM
SBates08's Avatar
SBates08
Take your ground wire from the radio and connect it to the black wire on the Metra harness. The way you have it the radio is grounded but the ASWC-1 isn't sensing that it is.
2010 Limited with some stuff
Old Apr 10, 2015 | 03:24 PM
BOSOXFan's Avatar
BOSOXFan
FIXED!!!! I am an idiot and needed to step away. rechecked all m connections, forgot to strip one of the constants inside the crimp!! Also went black to black!
Old Apr 10, 2015 | 03:26 PM
SBates08's Avatar
SBates08
Good deal.
Gunslingerglide
Audio Systems
18
Jun 16, 2017 06:50 AM
Wampuscat
Audio Systems
Oct 17, 2015 10:57 PM
Griff123
Electrical/Lighting/Alarm
May 5, 2014 12:26 PM
ShadoHawg
Audio Systems
Apr 18, 2013 03:08 PM
dres22
Aug 23, 2010 05:52 AM
