Boom audio stage 2 upgrade
Old Jun 15, 2015 | 03:37 PM
Roc2904's Avatar
Roc2904
Stage II
Default Boom audio stage 2 upgrade
Let me first say this is on a 2015 road glide special. I had the stage 2 amp and speakers installed at the dealership, I purchased the saddlebag amplifier and speakers stage 2 to add and try and install on my own. It seems with Harley's instruction manual you need to learn a foreign language to understand them. I'm wondering if anybody can simplify the install process at the point after speaker and amplifier have been installed in the saddlebags. Sorry you have to dumb it down a little bit for me to understand it any help would be appreciated.
Old Jun 15, 2015 | 03:54 PM
sbeast's Avatar
sbeast
the wiring should be fairly simple. rear-speaker wire goes from head unit to amp to speakers in bags. amp gets wired up to direct power, a relay for on/off, etc.
i dont know much about the Boom! system beyond the fact that it is incredibly low quality equipment sold for outrageously high prices
Old Jun 15, 2015 | 04:32 PM
dgreen1069's Avatar
dgreen1069
PM Copyless. He installed his system (before removing it) and may have some insight. All the connections are via wiring harness. The front amp uses the front speaker connections while the saddlebag uses the rear. The tourpak amp connects to the harness under the rear seat back so I'd assume the saddlebag amp does also. If you are on a Street Glide I don't know where the harness connects.
Old Jun 15, 2015 | 05:04 PM
Roc2904's Avatar
Roc2904
Stage II
I believe they are behind the left side panel where the fuse box is, that connection where the second amp gets the input from the radio ?
Dpgriffin2014
Touring Parts
Mar 29, 2020 05:10 PM
Michael R Moore
Jan 15, 2019 12:11 PM
Springerfan
Audio Systems
Jun 29, 2016 05:24 PM
smoothonet
Audio Systems
Jun 16, 2014 09:28 AM
Fire4Effect
Audio Systems
May 31, 2013 10:34 AM
