I'm running the PA RZ4 2000D, and I'm chasing an unknown problem. What are the symptoms of an amp in protect mode audio wise? Is it just silent? I developed what I can best describe as a chatter, sounds like it's turning off and on very fast several times a second. I originally thought it was a bluetooth connection problem with my former Sony DSX310. There is a reset button on those and after I reset it audio would come back breifly, then the chatter returned. Swapped that head unit out for a Sony MEX and all was well for several weeks but my problem returned. The RZ is 2 or 4 ohm compatable, but I'm running 2 ohm Kappas in the lowers and 4 ohm Pioneers in the lids in parallel on the rear channel (3 ohms?). I don't know if the amp is bad or if I need to replace the 2 ohm speakers with 4 ohm ones. I ran it like that for several months with the old DSX hu without an issue, and like I said it was ok for a short while with the new head unit. Thoughts?
You asked why your amp is acting weird, then described a situation that would result in too low an impedance, forcing your amp to work too hard and overheat.
I answered. Your impedance is too low.
If you can't wrap your mind around that, I guess I'm done here.
GM
John a 2 ohm speaker wired in parallel with a 4 ohm speaker = 1.3 load.
If an amp is in protect mode the on light should go red and it essentially shuts off. If u are getting distorted sound something may be cooked for prolonged use at 1.3 ohms.
I guess I'm missing something or I'm getting old. He can run the 2 ohm infinity's on the front channel alone. and run the 4 ohm pioneers in parallel on the back channel with out a problem with the RZ4.2000D. Now as GM said he can't run the 2 ohm speakers in parallel with the 4 ohm speakers on the same channel. Now what he can do is get a set of 4 ohm titan II speakers to run in his lowers. Running the 7.1's and the titan II's in parallel would not be a problem.
I have a total of 6 speakers Gannicus, with the aforementioned 2 and 4 ohm on the rear channel and BT 7.1's up front. Looks like I'll have to replace the Kappas with a set of 4 ohm 6.5's. Too bad, I like them. I see some Titans in my near future, and a chance to try the new PA 3000D. Groovus I appreciate your input. I was thinking if 4+4=2 in parallel, 4+2=3 ohm. I'm unaware of the mathematical formula used to calculate that load. As it stands now it's a moot point for the short term as I'm recovering from shoulder surgery and can't ride anyway.
So haze, what formula did you use to calculate total load?
