2 ohm parallel
Old Jul 1, 2015 | 01:11 PM
soberjoe's Avatar
soberjoe
Default 2 ohm parallel
What happens when you run two 2ohm speakers in parallel?
I have 2ohm in the faring and would like to add lowers. Can I run it in parallel off one 2 channel 2ohm amp?
Old Jul 1, 2015 | 01:27 PM
nineball's Avatar
nineball
you can only do that if your amp is 1ohm stable, which it more than likely is not. you would have to wire them in series and the amp would see a 4ohm load per channel.
Old Jul 1, 2015 | 01:44 PM
soberjoe's Avatar
soberjoe
Thanks for the quick answer. I figured it won't work but I had to ask.
Old Jul 7, 2015 | 06:53 PM
chrldo's Avatar
chrldo
what bike do you have? boom audio amplifier?
Old Jul 8, 2015 | 09:50 AM
just plain john's Avatar
just plain john
You can use two 4 ohm pairs in parallel on a 2 ohm amp.
Old Jul 9, 2015 | 10:29 AM
chrldo's Avatar
chrldo
I have 13 SG that has boom amp with boom fairing speakers and boom lower fairing speakers on front channel wired parallel and boom saddlebag speakers on rear channel. works great
Born2cure
Touring Parts
Jun 27, 2019 09:11 AM
Biggzed
Audio Systems
Jan 11, 2019 10:25 AM
Gambat
Audio Systems
Jan 5, 2018 09:28 PM
D.L.ANDER
Audio Systems
Mar 7, 2013 07:02 AM
kjkustoms
Mar 25, 2012 08:22 PM
