did you hook up the remote power on wire on the Amp? usually "blue" wire.
run it to f.e. headlight + or something you know will be on ASA you turn bike to ignition or Acc.
did you hook up the remote power on wire on the amp? Usually "blue" wire.
Run it to f.e. Headlight + or something you know will be on asa you turn bike to ignition or acc.
yes vtwin audio sold me a kit that was a direct plug and play for the remote wire,
Level 7 adds Remote turn on and precision SMT contruction over levels 3 and 5.
PRO Series 4-Channel High Power Line Output Converter
Designed to optimize audio levels between radio and amplifier to achieve the best audio quality
Ideal use when replacing factory (OEM) radio or amplifier Configurable for speaker level or RCA level input/output
Single dial, precision matched stereo, level gain adjustment
Signal-sensing circuit for amplifier remote turn-on
Surface Mount Construction (SMT) for reliable and noise-free operation
Ultra-compact size for greater installation flexibility
looks like maybe remote power on on the line convertor not connected or perhaps configuration incorrect - I am not familiar with this converter
