No sound now
Old Oct 13, 2015 | 09:40 PM
Egghead's Avatar
Egghead
Default No sound now
Just downloaded the newest software update to my 2015 SGS, I added Rockford amp and speakers a couple months ago and had no issues until now after I installed the update I have no sound???
Old Oct 13, 2015 | 10:08 PM
HD_Doobie's Avatar
HD_Doobie
Can you bypass the amp? Connect speaker outputs from head unit directly to speakers. Did you have the head unit flashed when you added the amp?
Old Oct 14, 2015 | 09:58 AM
Egghead's Avatar
Egghead
I can bypass it tonight, I just reinstalled the new update and still no sound, also the fader bar does not move anymore, I did have the dealer flash but I don't think it was the right flash he could not find where to turn the amp1 amp2 off.
Old Oct 14, 2015 | 11:23 AM
duglaura&flhti's Avatar
duglaura&flhti
I'm reading so much on flashing with updates, is this normal on the newer bikes? What's the cost for flash here, flash there? HD..Hundred dollars?
Old Oct 14, 2015 | 11:34 AM
FLYINGBROKE's Avatar
FLYINGBROKE
don't know of any updates that have caused complete loss of sound ,betting its no power to amp.
Old Oct 14, 2015 | 11:56 AM
Egghead's Avatar
Egghead
My dealer doesn't charge for the flash but I've read some charge between $25-$50
Old Oct 14, 2015 | 11:57 AM
Egghead's Avatar
Egghead
The amp was working fine for a couple months prior to doing the update, I talked to my dealer we are going to try a flash this saturday, I will post what I find out.
Old Oct 14, 2015 | 12:01 PM
Scott14SG's Avatar
Scott14SG
You didn't say if you have the REM wire connected or not, but that was an issue with my bike when I had an RF amp, couldn't get sound with any flash. Once the REM was hooked up everything was fine.
Old Oct 14, 2015 | 12:36 PM
Egghead's Avatar
Egghead
I used the Rockford Fosgate install kit and don't need to run a REM wire, I did have a working Fader after the initial Flash from the dealer but since the update I still have Fader option but nothing happens when I toggle it, this is why I think it may be a flash issue. I will try the REM if the flash doesn't take care of it ,thanks for the suggestion.
Old Oct 14, 2015 | 01:27 PM
FLYINGBROKE
Do the rem first common issue that will take care of power, flash is the issue with fader, try toggling fader then turn off bike completely and check position of fade it will change only bye doing it this way , then keep reading on this or any forum and you will understand that you screwed for now as far as having the system working properly.
